Had not driven van since friday, was on holiday, then sick. Its been raining a lot.
On ny way to work today, made it about a mile, van was running normal, pull up to drive through to get coffee, van died and wont start.
When i turned they key, gauges an dash lights work, engine cranks over but doesnt fire.
Got my coffee, pushed the van into parking lot. 4500 lbs and a 1000 in tools is heavy whew!
Started checking fuses. ECMB is blown. Replaced it cranked it over, same thing. Checked the fuse and it must have blown again immediately.
Whats a good strategy for tracking the problem down. Never had this issue before with any car.
Thankfuly im self emloyed so i wont lose my job but was going to be working with another guy today so im pissed this happened on a day when it will affect anothers schedule.
Thanks guys!
Edit: looking at the schematic in van manual. Looks like ECMB goes to fuel pump and fuel/oil pressure switch? Cant see anything else thats running off that fuse.
Edit2: so looks like it says "hot at all times" on that fuse.
I can put a new fuse in and it doesnt blow unless i turn the key. I just tested it and as soon as i turn ignition on SNAP the fuse blows.
Edit3: the side of the fuse thats not suposed to be hot has 0.3v coming out of it with key on, 0.4v when key off. Glad i checked to see it it was hot before testing resistance. Going to unplug battery and test continuity on that fuse pin.
Edit4: here is where things get strange and spooky...
I disconnected positive battery lead. Not sure why but i tested that pin again for voltage. Sounds stupid to do so right? Still getting 0.3v out of there! So with the battery disconnected where is this coming from?
Im starting to wonder if my battery is is leaking or something. Due to the heavy rain it looks like water was leaking under the hood and the battery is sitting in a puddle of water. Theoretically if theres a crack in the battery could current be leaking to the frame that way???
I was bork here but 9 months out of the year i hate the PNW but cant move because my wifes family is here. Would live to live in the desert lol.
Edit5: here is the strange part. I pulled the battery, and tested the positive battery lead to the battery holder plate. Still getting a small amount of voltage? Is that even possible? If enough battery acid leaked onto the plate could it basically create a mini battery there? Its not much but you can see in the picture what im talking about:
The battery tests at 12.6v, it was sitting for days and van fired right up this morning. So in a sense the battery is good but its still the same battery that was in the van when i bought it in 2018 so it wouldnt hurt to replace it. im only a block away from auto parts store.
Edit6: i just tested that fuse pin again and with the battery unplugged it still has 0.3v coming out of it, what the hell lol. Maybe its my multimeter. Going to walk home and get my klein and see if its the same deal. Man this is twiglight zone shit rigjt here.
The only other thing i can think of is the reptilian shadow government installed a mini nuclear or battery powered tracking device on my van somewhere while i was on vacation and its shorting to ground a little or something hahaha jk.
Edit7: walked home and got my klein. Still getting 0.25v coming out of that pin with the battery removed. Has been removed for about 45 min. Going to touch positive and negative battery terminals together for a few min to see if that gets rid of that... maybe theres a capaciter or coil or something that still has a charge in it???
Thanks guys!
