I backed out of my drive way and put it in drive... went 10 feet and she died
Had no spark to the plugs... checked coil... no spark coming from the Coil.
Have 11.14 volts on the +terminal when probed the coil
Voltage on the -terminal fluctuates while cranking.
I would guess that all means that everything up to that point is working correctly?
What I've replaced so far:
1. Coil
2. Spark plug wires
3. Spark plugs
4. Distributor cap
5. Rotor
I just installed the new coil (after drilling out the rivets of the old one while it was in place... that bracket is hell to try and take off)
I cranked the engine and heard a loud pop (guessing that was from gas in the cylinders from testing, meaning I'm getting spark to the plugs)
At least now it sounds like it's trying to catch... but very faint.
These are my questions:
1. Is there an easy way to put my finger in the #1 spark plug hole? or get my 15 month son to do it
cause it's a pain in the a** to get to them in the first place.
2. How would I test the pick-up coil on the distributor... that's the only thing on the high tension side I haven't checked yet.
3. I had the old coil disconnected completely and removed the rotor cap.. the rotor spins slow while cranking... don't know how fast it is suppose to be.
My battery is now almost dead (from death at street till now I've only cranked it around 20 times)
If anybody has had this issue or knows what might be wrong... I'd appreciate the help (it's my only vehicle and Christmas is coming)
1. Coil
2. Spark plug wires
3. Spark plugs
4. Distributor cap
5. Rotor
