Pam(last post about it)..Your '92 conversion van(just noticed) might be different and more complicated,maybe not.You should do a bit of exploratory work to see if it is somewhat the same..Sorry I didn't notice that before..but this carpet take out is for basic gen1 A &S vans.Compare yours to this 1990 original.
Rod..did you get that leak figured out...??? ..I didn't intend to take over the thread..sorry about that..(divert/delete the posts?..not a problem by me..)..
In building/construction..I've seen water run uphill under eaves and that ..why they usually added a small U channel under drip edges and bottoms of siding to stop it from doing that on close to level surfaces..On as much "rise" as the ribs have though from the side where the rails are mounted to the top of the console? seems a bit much for that from the rail mounts..what about condensation..frozen water inside.. ice melting.. above your insulating headliner..You think you found too much water involved for that? I have a ceiling console also..no water..
I mounted my own rails in a similar fashion as factory with nothing above the old headliner because I didn't know what would fit there or what condensation it would cause if I did insulate up there....???
Did you pull some trim and check the moisture at the rail mount point? Just wondering if I might be in for the same thing..or if you found something different.
