Anyone used western chassis lowering leafs? Thinking of getting some 2" lowered leafs. With some Belltech 2" spindles. Can't believe No one responded on the Slam air kit
Yeah, that's what I noticed too. And even then they all seem to want to raise high in the sky.markmitch said:most of the members that are still on the site are into the AWD models lately so you may not get an answer. I thought about using some lowering leaf springs for my 89 but I want to be able to toe my small camper so I probably won't lower it.
Get stock steel springs?90safari said:I was just wanting to find a replacement for the fiberglass spring, that didn't raise the rear more than it already is. I searched the forum (stock suspension) but still kept finding people wanting to raise the rear with S-10 springs.
Yeah, I was looking at that. I think I saved a link to some new "stock style" steel springs (it was a kit). I found the link in the stock suspension forum to them.AstroWill said:Get stock steel springs?90safari said:I was just wanting to find a replacement for the fiberglass spring, that didn't raise the rear more than it already is. I searched the forum (stock suspension) but still kept finding people wanting to raise the rear with S-10 springs.
For those that find this by search, I have done quite a few conversions using stock steel springs using the original steel spring hangers. You will have to change/modify the axle mount though 1990 Chevy Astro Provan Tiger GTv8 Pop-Up CamperYeah, I was looking at that. I think I saved a link to some new "stock style" steel springs (it was a kit). I found the link in the stock suspension forum to them.
A little bit BIGGER rear tire would be one easy solution.Mainly, I am thinking of closing the wheel gap a little so that a 225-60-15 tire doesn't look "skateboardish."
I think that is sensible. I would prefer to convert from one OE system to another OE system, then lower or raise as desired. The Western springs in question are patterned on the late style steel spring, not a replacement for the fiberglass spring. At least that is how I interpret the fact that they are for 1995-onward vans.For those that find this by search, I have done quite a few conversions using stock steel springs using the original steel spring hangers. You will have to change/modify the axle mount though 1990 Chevy Astro Provan Tiger GTv8 Pop-Up Camper
I would avoid the special steel springs that mount in the composite leaf hangers, but that is just me.
No one says you ONLY have to change the rears.I think that the raked look is a good effect on many vans, however I am not sure about it on my particular van with the "family" look it has..
I don't anticipate rubbing anywhere with my combination, but I will have to fit up the wheels and see where I'm at. I really wish I could get a 17" wheel in the style I want, or any style that I really like on a van. But I can't, so I'm stuck with 15".I'm actually running larger than stock tires. They rub at full lock a little with un-modified wheel wells and if I hit a dip while turning. I haven't had the front bumper on yet to check for interference. 2" drop spindles up front. Worn springs in the back. I put a belltech sway bar in the front and it seems to help a lot. 225/55r18 front 255/55r18 back. Haven't rubbed on the back yet even pulling a car trailer with car on it.
