In reading through the V-8 swap forum, the recommendation is to use a TBI injected V8 from a year as close to the one as the van is, which, if I remember correctly, included using a different ECM (the p/n escapes me now).
Anyway, wouldn't any V8 donor vehicle work out if you also use the ECM from that vehicle ? I spoke with someone at an parts store that already did a V8 swap into his bro-in-laws Astro, and he said all they did was take the donor engine, ECM and harness, and put it in the van.
The reason I ask is because I just ran across a couple of deal in my area....one is a 2000 3/4 ton Chevy van, and the other is a 2001 1-ton. Both are priced @ $800 (and probably $400 back from the scrap yard when done yanking parts) . I'm planning to take a look at them tomorrow to see what kind of condition they are in. I'm not sure what the engine's are yet, but the smallest both of those came from appear to be a 5.7L. Looks like the 2000 3/4 ton came with a 4.3 V6, 5 & 5.7L V*'s, and 6.5L Turbo Diesel. The 2001 came with 2 different 5.7's, a 6.5L Turbo Diesel, and 8.1L (496ci). Hmmmm.
If the engine good in the 1-ton, I thought $800 (minus scrap value) was a great deal for the engine and 14-bolt Corp. rear end.
Thanks for your time.
fN
fN
