Where to put jack stands
1 reading
23K views 21 replies 12 participants last post by  ADDvanced
I don't ever remember having a problem jacking up an Astro. A lift is not the only way to skin a cat or change leaf springs even. Just because you have access to a lift doesn't mean that you have to use it for this job or even that it's the best tool for this job.
If it's YOUR lift, they make extensions for the lift pads, they are often stackable.
The only job that I think a 2post lift is really the absolute best tool for the job is a subframe swap. Other than that it's usually just as easy for someone to use a jack and some stands. Sure it can make other things easier/faster, but it's a luxury not a necessity. In your particular case it seems like it's a hindrance.
