1 - 4 of 4 Posts
Best I can tell, the replacement fuel pump options for my 2003 Astro are as follows:
ACDelco 1775 or Delphi FG0288
Looks like they both require a new connector to be spliced into the wiring harness, so no advantage there... Other than that, any favorites and why?
Appears that either one is a good choice but if anyone has something to share, I'd love to hear the input - Thanks!
Discussion Starter · #2 ·
...Crickets...? Perhaps clarification on what I'm looking for here -
1) These are the correct fuel pump part numbers for a 2003 Astro without Robust Fuel System Sender option
2) Am I correct that either the ACDelco 1775 or the Delphi FG0288 will require splicing a new harness that is supplied with either of the pumps
3) Both pumps are good options and neither has any advantage over the other
Thanks again for helpful response!
Administrator
Everything sounds correct, either would be fine, replace the connector regardless, both are probably made on the same line.
If it were my decision I would probably install the Delphi.
1 - 4 of 4 Posts
