Actually there is an easier way, by the way I have no clue why some say to swap them, If you buy two sections of 1/4 inch steel plate I started with 6" X 6" leave frame mounts where the are, using the steel pates you can bolt the steel to the engine block allowing you to bolt the stock block mounts forward of where they were originally. I will see if I can get at least one side picture taken to show you how I have done it but mine is an AWD now. I did the same on a rear drive van in the past.. Let me know if you want me to try to take a few pictures.
