Last battery bolt threads I stripped on one of these side mount Astro ones was about 20+ years ago.I swore that I would never do it again! Having to take off the negative cable a lot of times,especially with the tight space for the negative and stiff wires..Yeah..it happened again!
Anyway..It's Interstate from Costco..Does the warranty cover that?Has anybody checked on that?
Is there a tap-out,larger bolt,or some fix possible that someone has done?I don't mind cutting a tap off to make the start threads larger to begin the hole.. if that has worked for someone.
The battery is virtually unused but 1 year old with 100 miles on it while working on the van...
I'm ready to install a switch on the neg line so I don't have to undo that damn connection again.
Just looking for better options..
