Is Threre a Difference Between 2WD/4WD Rears
Postby WVHotWheeler [OP] » March 4th 2011, 2:52pm
I found a Eaton Detriot locker 162C59A I would like to use for my 2005 2wd Astro, it is out of a 4WD S-10 Blazer 28 spline is there any differences between the two that would not allow the swap of the carriers ? they are both 7.625 rear ends, thanks for any help,Kenneth
WVHotWheeler
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: WVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full yearsWVHotWheeler has been a member for 10 full years
Topics: 10
Alias (AKA): Kenneth
Extra Info: soon 2 be custom
Return to Rear-End
It is currently April 18th 2021, 3:05pm
Rear-End Forum
