Hose from rear differential?
Postby binder [OP] » May 7th 2011, 10:30pm
I just noticed that a hose has come loose from the underbody of my 98 Astro AWD. It comes from the top of the rear differential and is maybe a foot or longer and has a plastic piece/plug on the end. Nothing leaking from it. It appears it was held to the underbody and the mounting bracket rusted away. Is this an overflow hose? Nothing is leaking and the van is working properly. I just am not sure what this hose is for and if I should be concerned?
binder
Years of Membership: binder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full yearsbinder has been a member for 12 full years
  • Differential Service Question
    by Sklar » October 23rd 2020, 7:00pm in Rear-End
    Last post by Sklar View the latest post
    October 23rd 2020, 9:04pm
  • Replacement differential cover bolts
    by rusticshack » December 12th 2020, 8:08pm in Rear-End
    December 17th 2020, 1:33am
    22
    February 28th 2021, 4:22am
Re: Hose from rear differential?
Postby paintdrying » May 8th 2011, 12:15am
Overflow hose. Hang it back up where it was. Yes it is important. I dont think chevy's have the same problems as the Toyotas so you should be fine
paintdrying
Topics: 94
Extra Info: 108 000
Postby binder [OP] » May 8th 2011, 12:30am
thanks for the quick response
binder
Postby Leeann_93 » May 8th 2011, 1:12am
Vent hose and yes, put it back where it was.
Postby longyard » May 8th 2011, 4:14am
If it's been out for any length of time, and you've driven through wet conditions, you may want to drain the differential and use the opportunity to refill it with fresh synthetic fluid. :2:
longyard
Years of Membership: longyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full yearslongyard has been a member for 9 full years
Topics: 35
Return to Rear-End
It is currently February 28th 2021, 4:22am
Rear-End Forum
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
Attached by: MI_Ghost
MI_Ghost
in Rear-End
Comments: 21
Date: Jan 25 '21
Time: 7:22pm
SportsBoy
in Rear-End
Comments: 21
Date: Jan 21 '21
Time: 1:15am
