"Check AWD" light goes on periodically
Postby JuneauCabbie [OP] » May 13th 2011, 2:30pm
This is a real puzzler! :banghead:
My "check AWD" light goes on once in a while, almost always after I turn the engine off and back on after I have driven my 2003 Safari for 50-60 miles or several hours. My Scangauge shows no codes set, and the light will not be on when I start the rig the next morning.
This happened before I changed the the tranni and diff fluids a couple of weeks ago, and then didn't happen for several weeks. Since the tour season is starting, and Taku Taxi 73 will be running all out for 12-15 hours 5 days per week, I'd like to fix this problem soon --- I will be driving 1000 miles/week by the midde of next month.
:layrubber:
I have a good wrench who does not over or under fill the fluids, and who used all GM fluids. Clues, anyone?
JuneauCabbie
Years of Membership: JuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full yearsJuneauCabbie has been a member for 11 full years
Topics: 30
Images: 24
Alias (AKA): JuneauCabbie
Extra Info: SXT 4.3L V6 AWD
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
    7
    11
    January 24th 2021, 10:35am
Re: "Check AWD" light goes on periodically
Postby Leeann_93 » May 13th 2011, 9:54pm
Without the code, it's impossible to tell. When you get the light, take it directly to your wrench and leave it running - see if he can pull the code. He'll need an ABS-capable scanner (not all scanners are equal) to do so.
Postby dualsport » August 31st 2011, 12:44am
Hey Cabbie- Did you ever get a resolve on this periodic AWD light? I've got a similar situation up here in Fairbanks and was hoping to find something on this forum.
Thanks...
'00 AWD Astro w/102k and counting...
4" lift (overland inspired)
Front: 2" zoneoffroad pucks & TB crank
Rear: superior leaf helpers & homemade shackle lift
235/75/15 BFG ATs
dualsport
Years of Membership: dualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full yearsdualsport has been a member for 10 full years
Topics: 5
Postby drmmhmd » August 31st 2011, 3:07am
clean the grounds, the 2003 (1999 onward) uses a shift control module in the transfer case, when the vehicle senses different wheel rotation velocities the transfer case electronically engages and drive is applied to the front differential. the most common problems are simply connections that are contaminated or grounds that are not grounding or grounding intermittently. one of the AWD error lights occurs when the front does not engage when wheel rotation velocity differs.
I have the same problem, the manual states it could be an open circuit from our transfer case shift control module to the transfer case encoder motor. I have not had tme to look at this because of weather and time but this is where I'd start.
drmmhmd
Years of Membership: drmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full yearsdrmmhmd has been a member for 9 full years
Extra Info: AWD 400 CID
Postby JuneauCabbie [OP] » September 1st 2011, 9:37am
dualsport wrote:Hey Cabbie- Did you ever get a resolve on this periodic AWD light? I've got a similar situation up here in Fairbanks and was hoping to find something on this forum.
Thanks...
Well, it finally stayed on long enough I could drop by a shop where they had the right scanner, and it was a DTC C3010. Motor A/B Circuit Open. Could be a worn encoder motor or just bad connections. I'm going to ask them to check connections/ground before ordering a replacement, since it will be up on the lift for something else. Found one on Amazon for $97, and labor would be about an hour.
I'm thinking it might be connection/ground because it's still intermittent.
Nice to see another Alaskan posting.
JuneauCabbie
Topics: 30
Images: 24
Postby dualsport » October 17th 2011, 11:29pm
I was actually in Jnu the other day for the first time and really, really enjoyed it. And I was wonderin if I'd run across an Astro/Safari cabbie! :)
I did manage to hit some of the highlights though, including a SE waffle- good stuff.
We just got our first real snow yesterday (didn't melt off) but I'm facing the ole AWD issue again. I'm fixin to crawl underneith in a few minutes. I'm just sharpening my focus here on the forum real quick...
Amazon, eh? I'll give 'em a looksie if it's the encoder.
Thanks for the tip.
235/75/15 BFG ATs
dualsport
Topics: 5
Postby strangerock » October 27th 2011, 10:53pm
My 02 got a C0310 , I was able to check the encoder motor when the light was active and found it was open ...until I tapped it lightly ...has a dead spot in the motor and that explains why it was intermittent. I was able to read and clear my own codes with a pc based scan tool and software with an OBD II terminal.
strangerock
Years of Membership: strangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full yearsstrangerock has been a member for 9 full years
Van Model Year: 2002
Return to Rear-End
It is currently January 24th 2021, 10:35am
Rear-End Forum
Attached by: SportsBoy
SportsBoy
in Rear-End
Date: Jan 21 '21
Time: 1:15am
Attached by: jmderyke
jmderyke
in Rear-End
Comments: 24
Date: Dec 30 '20
Time: 4:09am
jmderyke
in Rear-End
Comments: 24
Date: Dec 29 '20
Time: 1:03am
Safarimeister
in Rear-End
Comments: 17
Date: Dec 27 '20
Time: 5:17pm
dit
in Rear-End
Comments: 31
Date: Aug 28 '20
Time: 9:45pm
