G80 rear end with 180k, would you replace it when regearing?
Postby albrow100 [OP] » June 25th 2017, 11:54pm
I'm planning to regear my lifted 1997 gmc safari awd with 180K, and I'm debating if the factory g80 can be considered reliable at this point?
or If I should just get a Detroit trutrac or Yukon duragrip and call it good.
van sees mild off road 20% of its use.
Has anyone had a high mileage g80 fail?
I've seen companys who rebuild them and remove the centrifugal system for a spring loaded clutch design, but have found no diy information on this
albrow100
Topics: 30
Images: 18
Extra Info: awd
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
    December 3rd 2020, 11:28am
Re: G80 rear end with 180k, would you replace it when regear
Postby Zebediah III » June 26th 2017, 12:22am
If there is nothing wrong with it, replace it ASAP.
Just kidding.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby AstroWill » June 27th 2017, 3:40pm
If only mild off-road, and you are gentle with it, I see no reason to replace it.
Images: 443
Postby TurnNburn » June 27th 2017, 4:49pm
I would gladly take it off your hands when you put something serious in it. I have been mildly looking for a G80 for a while now. It will be going to a good home.
Why are you regearing? And what are you going from/to ratio wise?
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby timothy47130 » June 27th 2017, 6:51pm
If you plan on driving it hard and have the money budgeted to spend on a locking diff like a Detroit it will be a lot stronger and more reliable than the old g80 gov lock . The gov lock will gernade pretty quick under hard stupid driving conditions. You also have a point about replacing it because of the mileage. It's probably getting pretty loose and unless you are the original purchaser of the van, you have no idea how it was driven before you or if the rear end was even serviced regularly. Also new Gears aren't all that cheap these days and if that thing goes it will most likely damage the new gears. If it were me and I had the money set aside for it I would replace it.
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Extra Info: mark III conversion
Postby albrow100 [OP] » July 5th 2017, 6:45am
I'm regearing from 3.42 to 3.73 mostly because both diffs are making loud bearing noises and I figured why not at the same time
It will put me closer to factory ratios with the 31X10.5X15 I'm running
I've decided to replace it due to the unknown/cost of doing it again if I break it.
Now its a between a tru-trac and yukon duragrip, will decide and order soon
also the g80 will be up for grabs in a month or so hopefully
located in Portland OR
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby chevymaher » July 5th 2017, 12:53pm
I got the true trac. It is a good differential. It can deal with anything you can dish out.
Return to Rear-End
It is currently December 3rd 2020, 11:28am
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
