Re: Differential Rear End Oil Change - How does this look
Postby dnwong [OP] » September 2nd 2018, 4:59pm
I opened up the read end on my 95 astro with 90K miles. Just wanted to see if things look ok or need repair from those in the know. I have metal shavings around the magnet. Here some pics. I have trying to track down a noise when backup up with engine cold. Sounds a little like heat shield rattle but a deeper sound. Anyways here are the pics.
1995 Chev Astro Conversion.
dnwong
Years of Membership: dnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full years
Topics: 29
  • Differential Service Question
    by Sklar » October 23rd 2020, 7:00pm in Rear-End
    Last post by Sklar View the latest post
    October 23rd 2020, 9:04pm
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
    9
    91
    December 1st 2020, 4:31pm
Postby dnwong [OP] » September 2nd 2018, 11:50pm
So, it that considered a lot of metal shavings on the magnet?
Anything else I would check while I am in there?
dnwong
Topics: 29
Re: Re: Differential Rear End Oil Change - How does this loo
Postby AstroWill » September 3rd 2018, 12:00am
The magnet is there specifically for that, looks normal from over here.
Images: 443
Postby Leeann_93 » September 3rd 2018, 12:19am
Looks normal to me. It’s dust from wear but no chunks.
Use a can of brake cleaner and get out whatever is still sticking to everything. It works really well.
Then put it back together.
Postby 1lowcab » September 3rd 2018, 12:53am
Ditto, normal.
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Postby TurnNburn » September 4th 2018, 6:18pm
metal on metal is inherently going to wear even with oils lubricating them. at 90k with that much metal its probably the first time that rear diff has been serviced. totally normal amount of wear for the miles
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby MmusicmanMmusicman is online! » September 4th 2018, 8:16pm
They ALL have metallic fuzz on the magnets when you pull the cover.. it's just a matter of how much is too much. Unless you're having a specific issue, it's probably not a problem. Fresh fluid and your back on the move.
PS: I ALWAYS put the new gasket on dry... never a leak! Just be sure cover is clean and flat! Tighten bolts evenly and smoothly.
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Return to Rear-End
It is currently December 1st 2020, 4:31pm
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
