Speedo change for a different rear end ratio...
Postby Ksmith [OP] » April 14th 2020, 10:02pm
Hi all, the stock 3.23 rear end gave up on me so I had my mechanic install a 3.73 rear end in it's place. All I can say is WOW... what an upgrade.
So... now the speedo it wrong. It's off by about 11 or 12% Has anyone here dealt with this problem? Could you let me know what the easiest solution is.
Thanks,
Kurt
Ksmith
Years of Membership: Ksmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full years
Topics: 21
Alias (AKA): Brushfire
Extra Info: AWD Z71
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    Last post by Leeann_93Leeann_93 is online! View the latest post
    September 18th 2020, 12:11am
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
    9
    91
    February 28th 2021, 4:58pm
Re: Speedo change for a different rear end ratio...
Postby AstroWill » April 14th 2020, 10:21pm
Just have to change the settings in the PCM with a tech2 or other compatible tuner.
Images: 472
Postby Astrofarian » April 14th 2020, 10:37pm
Your profile says that your van is AWD....hope you changed the R&P in the FRONT diff, too?
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Ksmith [OP] » April 14th 2020, 11:06pm
I have an AWD as well... this is an addiction... what can I say.
Ksmith
Topics: 21
Extra Info: AWD Z71
Postby Mmusicman » April 15th 2020, 4:27pm
Ksmith wrote:Hi all, the stock 3.23 rear end gave up on me so I had my mechanic install a 3.73 rear end in it's place. All I can say is WOW... what an upgrade.
The perfect UPGRADE!!! Now wait until you put a V8 in it?
By the way... I love your white RWD van!!! (They are BOTH GREAT!)
The flames, side-pipes, and wheels combo are awesome!
It truly does look like the prefect Hot-Wheels toy van!
I'm old school, and have been "considering" a few options on my Astros... but not sure if I'd like the mix of old and new, but your's sure looks good. I have a set of side-pipes (from my 70's hot-rod shorty G-van) I may have to size up. They'd probably be a good fit on my V8 92 cargo shorty. Plain pipes exit out both sides (before tires) now. (If not I may throw them on my AWD van). My 92 already has the rake and fat-raised white letter tires on Centerlines.
The flames are exceptional on your van too.. I love the way they are done!
I've never had a wild custom paint job, but I'd sure consider one like yours!
Nice job on both! :thumbup:
PS: I see I've commented on your side-pipes before.. as well as the awesome engineering!
https://www.astrosafari.com/viewtopic.php?f=24&t=126058
Topics: 73
Images: 49
Postby Ksmith [OP] » April 18th 2020, 1:25am
Thanks. I really like the 2 wd Astro too... :) It gets so much attention where ever I take it. I think people are kind of shocked to see and Astro with so much love invested in it. LOL I did end up putting a muffler between the cat and the side pipes... It really sounded bad at highway speeds.
I'd say go for the wild paint, flames or just big stripes. People really get a kick out of them.
Kurt
Ksmith
Topics: 21
Extra Info: AWD Z71
Postby AstroWill » April 18th 2020, 4:29pm
AstroWill wrote:Just have to change the settings in the PCM with a tech2 or other compatible tuner.
There are a few people on here that can probably help you with that, including myself, if you don't have someone local.
Images: 472
Return to Rear-End
It is currently February 28th 2021, 4:58pm
Rear-End Forum
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
Attached by: MI_Ghost
MI_GhostMI_Ghost is online!
in Rear-End
Comments: 21
Date: Jan 25 '21
Time: 7:22pm
SportsBoy
in Rear-End
Comments: 21
Date: Jan 21 '21
Time: 1:15am
