by dit [OP] » August 2nd 2020, 5:50pm
by dit [OP] » August 3rd 2020, 6:21pm
by sixsix » August 5th 2020, 8:26pm
dit wrote: ...Go light with the Dremel as you still want the bearing to fit snug. Just remove what is needed on the inside of the inner race so it slips easily over the pinion.
by Rod's Trucks » August 5th 2020, 9:47pm
by dit [OP] » August 6th 2020, 5:16pm
by dit [OP] » August 7th 2020, 4:11am
by dit [OP] » August 7th 2020, 11:02pm
by dit [OP] » August 21st 2020, 3:24pm
by markmitch » August 21st 2020, 4:49pm
by dit [OP] » August 22nd 2020, 5:54pm
by markmitch » August 22nd 2020, 10:01pm
by AstroOafAdventurer » August 22nd 2020, 11:06pm
dit wrote:I really didn't *want* a beefier rearend, this entire project is so I can put in a selectable locking diff. With the COVID the project is really getting backed up. Eaton keeps putting off their 8.8 production a month at a time. I may have to go with an OX locker instead.
The 7.5 is fine for my application but no options for a selectable locker. As for the G80, I'm not sure I'd take the time and money. They often fail; mine blew up first time I took it off road....
I will likely have a complete 7.5 truTrac with 4.10s available when the time comes.
by M_a_t_t » August 23rd 2020, 12:07am
by dit [OP] » August 27th 2020, 3:33am
by TowVan » August 27th 2020, 5:40am
by dit [OP] » August 28th 2020, 9:23pm
TowVan wrote:From what I've read on the "net," (so it must be true!) the 8.8 is an almost direct copy of a chebby design - just changed enough to not be sued. Haven't heard if that's a 10 bolt, or 12 bolt, but I always assumed a 10 bolt. I know its not as strong as a 9'', but not as much parasitic loss as a 9" either. 'Course I know there are some versions of a 10 bolt that are stronger than others...
But it doesn't surprise me to hear that the 8.8 has better aftermarket versatility!
by dit [OP] » August 28th 2020, 9:40pm
by dit [OP] » August 28th 2020, 9:52pm
by CopperFiremist
» August 28th 2020, 10:17pm
by WinnieVan » August 28th 2020, 10:41pm
It is currently January 25th 2021, 8:10am
Rear-End Forum |
Previous topic Next topic |
Sponsors |
