I have a 1999 2wd van with a failing rear end. A friend is going to junk her 2005 rwd van because the transmission is toast (3/4 clutch pack entirely hosed so there's no connection between the engine and driveshaft in 3rd, and a somewhat tenuous connection in 4th). However her rear axle assembly is in really good shape compared to mine. And it's so quiet!!
I know the 2005 has 6 lug flanges vs 5 on my 1999, but is that the only important difference?
Is the ABS set up differently on the 2005 vs the 1999?
What makes the most sense if I can use her axle assembly:
1. Also swap the front rotors and etc. so I would have 6-lug wheels on all axles, or
2. Pull out the axles from each of the two rear ends and swap them too, so I would still have my original 5-lug axles but her housing and rear end, or
3 ???
If swapping the front axle parts isn't too difficult I would prefer to do that instead of putting the 1999 axles in the 2005 housing. The 2005 is running so well that all I want to do with it is change the lube but otherwise not disturb it.
Thanks in advance for your suggestions.
