by rocketeer [OP] » November 13th 2020, 8:59pm
by dcsleeper » November 13th 2020, 11:23pm
by MechBob » November 14th 2020, 12:17am
by pmou » November 14th 2020, 1:24am
by dcsleeper » November 14th 2020, 1:58am
pmou wrote: I reached out to them about adding a limited slip diff and Adam (owner) told me if i showed up with the carrier they would probably charge around $800 - 1200 to install with shims, bearings, etc.
Also know that LKQ pick n pull has 4-5 astros on the lot at any time and a big ol pile of axles. Could pick one up and have it re-man'd then install yourself.
by rocketeer [OP] » November 14th 2020, 2:15am
by rocketeer [OP] » November 14th 2020, 2:18am
by rocketeer [OP] » November 14th 2020, 2:22am
dcsleeper wrote:You should be the 'rebuilder' , like a general contractor.
Find a local shop that can do this work:
Replace carrier, carrier bearings, pinion bearings, ring and pinion gears, axle bearings and seals.
IF the pattern looks good, you could re-use the R&P gears, saving a good bit of work and cost.
It's a 7.6 carrier, google.
for it to be noisy it is likely carrier bearings, and/or spider gears, not the R&P. R&P problems usually go very badly pretty quickly.
There's no way I would pay 2800 no matter what. you will probably land at 1500.
by Rod's Trucks » November 14th 2020, 2:50am
by MechBob » November 14th 2020, 3:14am
by MechBob » November 14th 2020, 3:43am
by pmou » November 14th 2020, 3:49am
by markmitch » November 14th 2020, 4:49pm
by rocketeer [OP] » November 14th 2020, 5:39pm
by dcsleeper » November 14th 2020, 5:46pm
by rocketeer [OP] » November 14th 2020, 6:01pm
dcsleeper wrote:There's no point in that. Just rebuild yours.
Some may disagree but a JY replacement has a good chance of being serviceable for quite a while.
I went thru several weak Chrysler rear ends in another car. Each one lasted more that 2 years each.
And it's cheap. Imagine some idiot ran a light and totaled your van on the way home from the garage after a $2K rebuild?
by AstroWill » November 14th 2020, 6:21pm
dcsleeper wrote:Some may disagree but a JY replacement has a good chance of being serviceable for quite a while.
It is currently January 28th 2021, 3:17pm
Rear-End Forum |
Previous topic Next topic |
Sponsors |
