Little gas turning left and a pop
Re: Little gas turning left and a pop
Postby jmderyke [OP] » December 30th 2020, 4:09am
I think I have to take some responsibility why my spiders failed. When I got this rid a couple years ago it's always has some very slight rear end sound. I looked it up and a lot of folks described what I was hearing as normal....ok? .....
I changed the oil and it looked well over due. I've only put 5k miles on the van since, the oil looked pretty nasty again the other day. I would have really enjoyed just swapping out the spider gears but i think the bearings have some slop to them needed a full rebuild.
Had some luck today, friend of a friend had his parents wrecked astro sitting on his property for a few years and guess what gt4 rpo! Just what I needed! Did some trading for help fixing his car and just had to take it out of the van.
Replaced the fluid, new gasket, a new lug stud and the brake line was smashed. Other than that the rear end looks pretty good.
So......I'm already thinking about building the original rear end, what locker should do you guys recommend? Isnt the ox locker cable actuated? I kinda like the sound of that.
jmderyke
Years of Membership: jmderyke has been a member for 3 full yearsjmderyke has been a member for 3 full yearsjmderyke has been a member for 3 full years
Topics: 21
Images: 2
Alias (AKA): jd
Extra Info: 4x4 lifted
  • Groaning New Summit LS Differential and Ring & Pinion
    by Safarimeister » December 26th 2020, 8:35pm in Rear-End
    January 17th 2021, 2:00am
    7
    21
    April 17th 2021, 4:01am
Postby Leeann_93Leeann_93 is online! » December 30th 2020, 4:14am
Sweet!
Postby jmderyke [OP] » December 30th 2020, 4:58am
I'm starting to see my locker options are limited, all I've found are auto lunchbox lockers or lsd. Dang
jmderyke
Topics: 21
Images: 2
Alias (AKA): jd
Postby markmitch » December 30th 2020, 6:16am
Great find!!!
Firing on 8 Cylinders (L6)
Topics: 629
Images: 21
Extra Info: RS V8 AWD
Postby ptysiek » December 30th 2020, 11:06am
I was cut out of these modes after about 120,000. There was no damage, but it was ground, as if badly hardened. I bought used dyes, replaced the bearings with new ones and already over 200,000 and it's ok.http://www.vanklub.pl/index.php?action= ... 2400;image
ptysiek
Topics: 7
Alias (AKA): Marek
Previous
Return to Rear-End
It is currently April 17th 2021, 4:01am
Rear-End Forum
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 4:49pm
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 3:20pm
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
