by Safarimeister [OP] » December 26th 2020, 8:35pm
by markmitch » December 26th 2020, 9:07pm
by chevymaher
» December 26th 2020, 9:11pm
by Safarimeister [OP] » December 26th 2020, 9:30pm
by dcsleeper » December 26th 2020, 10:31pm
by Mmusicman » December 26th 2020, 10:47pm
dcsleeper wrote:If there is no noise going straight it is likely NOT the pinion depth or side offset.
by MechBob » December 27th 2020, 1:01am
by Safarimeister [OP] » December 27th 2020, 7:03am
by AstroWill » December 27th 2020, 7:38am
by MechBob » December 27th 2020, 7:45am
by AstroWill » December 27th 2020, 7:58am
MechBob wrote:So,as you have not replied reliably,is your "new"limited slip a aftermarket clutch limited slip.a thorsen,or that type, or a GM type,g80 slip/locker, or a "lunchbox locker"? Information is the key.
by MechBob » December 27th 2020, 8:41am
by chevymaher
» December 27th 2020, 12:30pm
by Mmusicman » December 27th 2020, 1:46pm
Safarimeister wrote:This was the first time I drove over 40mph since I added the TransX modifier. I don't believe I am hearing any issues in the rear while driving, it's just louder than I am used to given I have no seats and it's an open box right now.
By the time I got home, the chatter/groaining seemed to settle down
by Safarimeister [OP] » December 27th 2020, 5:10pm
Safarimeister wrote:... The rear end groans, growls, low binding sounds when turning. Typically louder if you turn more than 30 degrees...
by Safarimeister [OP] » January 17th 2021, 12:48am
by markmitch » January 17th 2021, 1:52am
by AstroWill » January 17th 2021, 2:00am
Safarimeister wrote:So after an unsuccessful effort adding TransX friction modifier with no improvement, I pumped out around half the gear lube and added the Ford product then topped off with gear lube.
Within 10 minutes and a few figure 8s voila! The groaning was all gone.
It is currently February 28th 2021, 7:13am
Rear-End Forum |
Previous topic Next topic |
Sponsors |
