Is it possible to get polyurethane shackle bushings?
Postby SportsBoy [OP] » January 21st 2021, 1:26am
I am looking for polyurethane replacement bushings for the stock shackles on my van. The shackle to frame connection to be specific.
I removed the shackles, got the rubber out, bonked out the metal cups the rubber was in, and cleaned them up.
I took a lot of measurements with my calipers of the shackles and stock sleeves (there were two per shackle because there was a bushing pressed into each side of the shackle). I also have Prothane 19-608 for reference, as I had thought they would fit. It is not so. They are too small of an OD and definitely too short
Pictures are attached, but here are the important measurements -
- ID of shackle ~ 1.61"
- Length of shackle ~ 3.93"
- Width of shoulder needed - 0.25"
- OD of stock sleeves - 0.82"
- ID of stock sleeves - 0.62"
- Length of stock sleeves - 2.23" (x2 per shackle)
I have emailed many companies that produce or sell poly bushings this past week and have not gotten any helpful responses.
Does anyone know of a bushing that will work for our stock shackles?
It seems like I have a couple options -
- buy multiple sets, then shave them down so the OD fits inside the shackle, and cut the hat off another to fill the gap in the middle. Then get/make a sleeve that is long enough.
- install new metal cups like there were before, and put bushings in that will fit - still will probably have an issue with gap in the middle and sleeve length
- other???
The few other threads on this forum and the other where people are looking for bushings all seem to assume the cups are being left in, or it is for non-stock shackles. So, unhelpful.
I had no idea replacing these bushings was going to be such a pain. I am considering going back to rubber just to get it done - but I really want poly for ease of install and replacement more than anything.
Anyone have any ideas for me on where to get these? Thank you!
Metal cups that were in there - you can see how there is a gap in between - one was pressed in from each end
Smashed the metal cups out
Stock shackle measurements
Stock sleeve measurements
There were two of these sleeves per shackle - since there was one in each half of the pressed in bushings
Measurements of Prothane 19-608 for comparison - these fit the leaf spring eyelets perfectly. But, the length is far too short, and the outer diameter is just a bit too small
Clearly Prothane 19-608 is far too small
The shoulder is the right size though - it fits in the shackle to frame connection well.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Re: Is it possible to get polyurethane shackle bushings?
Postby SportsBoy [OP] » January 23rd 2021, 6:36pm
Still wondering if anyone has info about this?
At the moment, it is looking like I will do this unless I hear otherwise:
- Buy 2x 4-7/16" long, 3/4" od, 0.56" id, .095" wall thickness stainless tubing from here - https://www.speedymetals.com/pc-3430-82 ... -tube.aspx
- Buy 6x these poly bushings, 43mm od, 3/4id, 0.25" shoulder thickness. I'll cut the hat off two of them and use them in the middle. https://www.offroaddesign.com/catalog/p ... egory/415/
I might have to sand down the od of the bushings just a bit to get them to fit, as 43mm is like 1.69".
Not ideal, but this is the best option I've found so far.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby dcsleeper » January 23rd 2021, 7:08pm
measure your center to center distance of your stock shackles and tell me.
I will see if you can just drill holes in the lift shackles and use those.
reasons: cheaper, availability
https://www.amazon.com/Silverado-Adjustable-Lowering-Shackles-Leveling/dp/B071VR3TQT
also, I don't think you need to fill the entire length of the bolt.
102844
Profile | Edit signature
dcsleeper
Years of Membership: dcsleeper has been a member for 1 full year
Topics: 21
Images: 79
Alias (AKA): DC
Postby astroracer » January 25th 2021, 3:16pm
Got to your LAP and have them cross reference the part numbers for your van to any other GM vehicle. You will find many of the suspension components like bushings are widely used across the van and truck lines. Knowing what else will work can open up the sources for finding what you need. :)
Mark
1994 Astro with an LT1 350 (Ron Burgundy)
2004 Astro
2000 Monte Carlo SS
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Firing on 7 Cylinders (L1)
Years of Membership: astroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full years
Topics: 13
Images: 2
Alias (AKA): astroracer
Van Model Year: 1988
Extra Info: Major renovation
Postby MI_Ghost » January 25th 2021, 4:03pm
What about the possibility of swapping the s10/blazer shackles?
Anybody got specs for those?
Stock Shackle Bushing specs
ACDelco Pro 45G15393
Outside Diameter: 42.7 MM
Thickness: 28.45 MM
Height: 76.2 MM
Inside Diameter: 0.560 IN
Interchange Part Number: 274-6977, 35400, 576-3393, 576-3393B, 88913006
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby SportsBoy [OP] » January 25th 2021, 6:36pm
dcsleeper wrote:measure your center to center distance of your stock shackles and tell me.
What do you mean by this?
astroracer wrote:Got to your LAP and have them cross reference the part numbers for your van to any other GM vehicle. You will find many of the suspension components like bushings are widely used across the van and truck lines. Knowing what else will work can open up the sources for finding what you need. :)
Mark
Good point, I should go ask Autozone
MI_Ghost wrote:What about the possibility of swapping the s10/blazer shackles?
I believe the upper part of the shackles on other vehicles is too narrow compared to ours, not sure though.
However, if 42.7mm is really the od of stock replacement shackle bushings, then the 43mm od for the poly bushings I found is darn close. That's nice.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MI_Ghost » January 25th 2021, 7:22pm
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby dcsleeper » January 25th 2021, 7:29pm
the 4.415 dimension in the pic above
dcsleeper
Topics: 21
Images: 79
Alias (AKA): DC
Postby CopperFiremistCopperFiremist is online! » January 25th 2021, 10:00pm
Pullin The Pass
Firing on 1 Cylinder (L2)
Years of Membership: CopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full years
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby SportsBoy [OP] » January 25th 2021, 10:59pm
Yep, posted in there, but the answer isn't in there.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby SportsBoy [OP] » February 8th 2021, 3:11pm
SportsBoy wrote:Still wondering if anyone has info about this?
Ok, as an update, I did end up donig this.
One note - the shackle bolts are m14 (14mm) - which is slightly smaller than 9/16". 9/16" bolts won't fit in these stainless sleeves.
Got the tubes in the mail and filed the ends to clean them up. Got the bushings in the mail too.
Used a belt sander to shrink the diameter a bit - which took kind of a while and made a mess. If you had a bench mounted sander rather than a hand held one I'm sure it would be WAY EASIER
Cut the end off one with a razor blade - not easy either.
The cleaned up and painted shackle it went in
Got it all lubed up and tapped everything in with a hammer
No pic of it installed yet - though it is in with the leaf spring attached.
It was a snug , but good fit - I think a 4-3/8" sleeve would have worked as well and tightened up just fine. 4-7/16 was definitely just a hair less than the space.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MI_Ghost » February 9th 2021, 7:31am
Thickness: 28.45 MM
Height: 76.2 MM
Did some back tracking on the interchange for this and got broadsided by the :chevy: C1500.
88-98 Chevy C1500 RWD also use this bushing.
The good news/bad news is that the poly version is available in the Prothane 7-1055 kit, but the leaf spring bushings are the RB172 bushings. The Astro/Safari leaf springs use the RB255 leaf spring bushings.
The only other issue I see is the 3 inch length will need a longer inner sleeve for the bolt and leave a 1 inch gap in the middle of the shackle. :shrug:
But all is not lost. :shrug:
Everyones favorite S-10 leaf spring does use the RB172 bushing.
The 7-1055 kit will work for the S-10 spring swap.
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby SportsBoy [OP] » February 10th 2021, 11:44pm
I'm confused, this doesn't look like it would work. The shackle bushings are bigger than the leaf spring bushings on our van, not smaller as in this picture.
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MI_Ghost » February 14th 2021, 7:01pm
Be careful how you look at pictures. Those big bushings on the right are for the leaf spring.
The shackle bushings are the left side. Note the difference in the flange area.
I am also wondering about this as they only provide the 3" sleeve.
I keep running into conflicts between spring and bushing specs. :confused:
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby SportsBoy [OP] » February 15th 2021, 3:04am
MI_Ghost wrote:Be careful how you look at pictures. Those big bushings on the right are for the leaf spring.
Exactly, on our vans the leaf spring bushings have a smaller diameter than the shackle bushings, so if the biggest bushings there are for the springs, then that kit won't fit.
As I mentioned, I did take a pic of the shackle installed - the first 50 miles went well!
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MI_Ghost » February 15th 2021, 4:59pm
Correct. As noted in my post.
Only the shackle bushings in that kit will work for our vans.
I am still looking to see if the shackle bushings can be found ouside of a full kit.
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby AstroWill » February 15th 2021, 9:34pm
Would be nice if they made an all-in-one kit for our vans instead of having to find pieces here and there.
Good work guys!
Images: 473
Postby SportsBoy [OP] » February 15th 2021, 10:27pm
Ok, I'm confused - we've got to be miscommunicating here somehow.
The leaf spring eyelets, at least on the 22-687hd's I just swapped are 1.5" diameter.
The stock van shackle are ~1.63" diameter bare with no sleeve.
If the largest bushing in that kit is for the springs, it would have a 1.5" diameter.
Meaning it would be too small for the shackle.
Am I still misunderstanding what you're getting at?
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby SportsBoy [OP] » February 15th 2021, 10:28pm
AstroWill wrote:Would be nice if they made an all-in-one kit for our vans instead of having to find pieces here and there.
Good work guys!
I know right??????
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MI_Ghost » February 15th 2021, 11:36pm
SportsBoy wrote:
MI_Ghost wrote:Correct. As noted in my post.
The kit is for the 22-1221 springs for the C1500/Siverado. Which has a bigger front spring eye.
The 4 big bushings are the 2.0" RB250 bushing for the front spring eye.
The 4 middle bushings are the 1 11/16" RB172 bushing for the rear spring eye.
The 4 small bushings on the left are the shackle bushings. Note the smaller Flange/lip.
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Return to Rear-End
It is currently April 13th 2021, 2:34am
Rear-End Forum
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 4:49pm
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 3:20pm
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
