Axle questions...
Axle questions...
Postby jrsride2002 [OP] » May 28th 2012, 8:07am
OK, so I have been wanting to get different rims AND do the enlarged brake system. Still doing my homework on the jobs.
For the most part, I am building my van up for towing abilities. Did the cooler, got the air bags for more weight, brake controller soon to happen, and the hitch is mounted. Bikes, cars, travel trailer, whatever I can haul, will be hauled.
I know the 03-05 Astro axles will swap over to my 01, and I would have the rear disc brakes because of that.
1.) I have been under the impression, in general disc brakes are great, but for towing, drums are the way to go... Wright or wrong?
2.)I know with the 5 lug system, larger drums and rotors are easy to come by at the J/Y. I wanted to know, what the 6 lug systems? Are their any larger discs or drums I would want drop in? As far as rims go, I dig the Silverado 6 lug chrome rims, and see them cheap on craigslist, kind of often.
3.) What is the average gearing on those diffs? Right now I have 3.43's(I think, its been a while since I ran my vin)
Is that swap worth the time and effort?? An I forgetting to ask something else?
Thanks guys
~Junior
jrsride2002
Years of Membership: jrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full years
Topics: 37
Images: 21
Alias (AKA): Junior
Van Model Year: 2001
Extra Info: LS V6 RWD
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
  • Put in 2005 axle assembly on a 1999 Van?
    by Silver99 » November 2nd 2020, 3:42am in Rear-End
    Last post by SainT View the latest post
    November 4th 2020, 9:26pm
    56
    January 17th 2021, 10:45am
Re: Axle questions...
Postby Leeann_93 » May 29th 2012, 2:23am
I wouldn't worry about a brake swap. If you're going to tow heavy trailers, you need a trailer with brakes and a brake controller.
3.42 is the diff you'll find most often on these. 3.73s are a bit better for towing, but you do lose a little mileage with them. My Safari has 3.42s but my Bravada and Astro both have 3.73s.
Postby jrsride2002 [OP] » May 29th 2012, 8:44pm
Leeann_93 wrote:I wouldn't worry about a brake swap. If you're going to tow heavy trailers, you need a trailer with brakes and a brake controller.
Totally agree about 3.73's being better for towing. However, I have not bought a trailer yet, so I want to be prepared for buying something that doesnt have breaks already. I want the price to be as cheap as I can, and if that means adding breaks to the trailer later, then so be it. But for right off the bat, I want the machine to be ready for a trailer without. So I am going to be doing the swap.
One other thing, another reason why I asked about the 6 lug is because I also saw a 2500 truck with 13"(or larger, not sure) drums on a 6 lug and wondered about that going on a 6 lug Astro axle.
Thanks
~Junior
jrsride2002
Topics: 37
Images: 21
Alias (AKA): Junior
Return to Rear-End
It is currently January 17th 2021, 10:45am
Rear-End Forum
Attached by: jmderyke
jmderyke
in Rear-End
Comments: 24
Date: Dec 30 '20
Time: 4:09am
jmderyke
in Rear-End
Comments: 24
Date: Dec 29 '20
Time: 1:03am
Safarimeister
in Rear-End
Comments: 17
Date: Dec 27 '20
Time: 5:17pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
