Humming noise
Humming noise
Postby SafariRulez [OP] » March 18th 2013, 2:59pm
You probably heard this a million times!
I'm getting a humming noise in the rear end when I go 100 + king, even in neutral.
I changed the rear wheel bears and put new diff fluid in. The noise is still there! What the heck can it be?
Thanks for your help
SafariRulez
Years of Membership: SafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full yearsSafariRulez has been a member for 8 full years
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
    60
    October 25th 2020, 5:30am
Re: Humming noise
Postby SafariRulez [OP] » March 18th 2013, 3:14pm
King = Km/h
SafariRulez
Re: Humming noise
Postby RECox286 » March 18th 2013, 5:38pm
Not enough information, please say what tune it hums... Or hold the phone closer to it while you are driving !
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Humming noise
Postby RECox286 » March 18th 2013, 6:00pm
Does the hum intesify with speed; less at lower speed, more at highter speed ? Did you check the axles for wear at the spots
where the axle bearings touch the axles ? If there were bad spots on the axle, did you 1) R&R axles, or 2) use offset axle bearings ?
What did you use for gear lube ? (Inquiring minds would like to know.)
Uncle Bob
NOTE: The 10 bolt axle is a semi floating type. This means that the outer part of the axle is held in the center of the
axle tube by the axle bearing, and the axle itself becomes the inner race. Not the best of designs, but it does
accomplish the job. However, and mostly due to lack of lubrication, the bearing/axle can and does heat up,
destroying one another. It is usually a good idea to use wheel bearing grease, to pack the axle/bearing/seal
when reassembling after bearing replacement. Once the axle is scored by the bearing, it was once a given that
the axle needed to be replaced. More recently, there is an offset bearing available that moves the rollers to a
fresh spot on the axle, eliminating the need for axle replacement until such time that the axle becomes scored
on the "new" bearing surface.
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Re: Humming noise
Postby SafariRulez [OP] » March 18th 2013, 8:10pm
Is a low pitch hum and it gets louder when you drive faster
SafariRulez
Re: Humming noise
Postby chevymaher » March 18th 2013, 8:27pm
The majority of rear ends do hum. Vans just have the disadvantage of having a sound amplification system built in. And the rear of the van has good acoustical value. And due to the back not having sound insulation. Such as a back seat. Rear end gears meshing has a sound even when nothing is wrong.
The difference is. Is it a normal good sound or a I am wore out growl sound.
My vans rear end was wasted bearings and gears. It was growling.
I used all performance parts rebuilding it. Now it sounds exactly like the chevelles rear end. Nothing like it sounded before. But even new it had a sound.
Re: Humming noise
Postby Don1806 » March 18th 2013, 8:36pm
Don't rule out tire noise unless you have a brand new set on the rear. I have chased noises on my van and my car only to find out they went away when I replaced the tires. It will drive you nuts.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full years
Topics: 18
Images: 2
Alias (AKA): Don
Extra Info: AWD 170K
Re: Humming noise
Postby xit » March 18th 2013, 8:56pm
Mine had a little noise before I put on new tires & it went away just like that. :D
Possibly Natures most perfect food, good beef jerky and cold beer......
xit
Years of Membership: xit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full years
Topics: 65
Images: 4
Extra Info: Conversion
Re: Humming noise
Postby SafariRulez [OP] » March 18th 2013, 11:01pm
The thing is one day I was driving and I hit a pot hole. Soon after I heard crackling and almost like a set of keys dragging on the floor, coming from the rear end. I stopped the truck and looked underneath but didn't notice anything unusual. And then soon after that I noticed some roaring coming from the rear end when I got onto the hwy. That's why I thought to change the rear wheel bearing and diff fluid.
SafariRulez
Re: Humming noise
Postby chevymaher » March 19th 2013, 12:36am
Now it makes sense. Check for a bent axle.
Return to Rear-End
It is currently October 25th 2020, 5:30am
Rear-End Forum
dit
in Rear-End
Comments: 23
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 23
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 23
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 23
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 23
Date: Aug 06 '20
Time: 5:14pm
