99 safari, rear wheel chirp when tight cornering
Postby texaszero [OP] » April 9th 2013, 8:19pm
I have a 99 safari that one of the wheels seems to chirp when turning sharp. Is this common, due to tge type of rearend?
Thanks
Johnny
texaszero
Years of Membership: texaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full yearstexaszero has been a member for 8 full years
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
    7
    37
    November 25th 2020, 2:10pm
Re: 99 safari, rear wheel chirp when tight cornering
Postby Ragenme » April 9th 2013, 8:24pm
Is it RWD or AWD?
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Extra Info: SLX 4.3 V6 RWD
Postby texaszero [OP] » April 9th 2013, 8:45pm
Awd
texaszero
Postby Ragenme » April 9th 2013, 9:39pm
Sounds like it maybe binding a bit.
Ragenme
Topics: 16
Images: 23
Postby thegreenmachine » April 10th 2013, 4:26am
Rear could be barking at lower speed tight corners. If it has a G80 rpo code it has a factory locker. So it's not an open diff.
Mine spins a tire leaving my driveway everyday until the front kicks in.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Return to Rear-End
It is currently November 25th 2020, 2:10pm
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
