Diff Job
Diff Job
Postby hangmans8 [OP] » March 4th 2009, 4:42am
I got my van with a blowen diff. i have a problem putting the same small diff in. I'm in the middle of putting in a 12 bolt truck diff.
With 8 7/8" ring gear , it will be a little stronger. The size of the brakes are alot bigger. the only difference is spring perches and diff yoke. i have to shorten the drive shaft 1". It will be a good fit. drum to drum is only 1/2" different.
:twisted: i figered a 9.5 14 bolt would be to big or is it too big?
hangmans8
Years of Membership: hangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full yearshangmans8 has been a member for 11 full years
Alias (AKA): hangman
  • Rear Diff code (on diff)??
    by Rod's Trucks » February 14th 2020, 6:18am in Rear-End
    February 14th 2020, 4:11pm
    42
    August 13th 2020, 1:11pm
Re: Diff Job
Postby astro355 » March 4th 2009, 5:42am
It would be fine. You may lose some horsepower turning that thing. What bolt pattern does that rearend have?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: Diff Job
Postby hangmans8 [OP] » March 4th 2009, 4:11pm
it that 6x5.5 but i got new 5x5 axles
hangmans8
Re: Diff Job
Postby astro355 » March 4th 2009, 4:24pm
Yeah, that will work fine for you. Just be warned that the van will feel a little sluggish on acceleration.
astro355
Return to Rear-End
It is currently August 13th 2020, 1:11pm
Rear-End Forum
dit
in Rear-End
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Date: Aug 06 '20
Time: 5:14pm
dit
in Rear-End
Date: Aug 03 '20
Time: 6:15pm
dit
in Rear-End
Date: Aug 02 '20
Time: 5:36pm
