How much difference from 4.73 to 4.42??
Postby swharris [OP] » August 4th 2013, 12:44am
So I found a good rear end for a reasonable price from a '99 today to replace the cracked one in my '97 Astro. All I had to do was remove the u-joint and out she rolled as someone before me had taken the springs.
Unfortunately, it's a GU6 as I could not find a GT4 today like originally came with the '97. I can return it if need be, but don't want to, if the difference in ratios is not that big a deal. I'm not too concerned with the speedo difference, just that the van will be able to pull the taller gear. This motor has a well maintained 280k miles on it btw. I guess my mileage may go up with the taller gear....
:banana: .
Any issues deal breaker issues I should know about before I throw it in?
swharris
Years of Membership: swharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full yearsswharris has been a member for 11 full years
Topics: 81
Images: 4
Alias (AKA): S4
Extra Info: 4.3 Vortec 2wd
Re: How much difference from 4.73 to 4.42??
Postby Corsemoto » August 4th 2013, 12:56am
3.73 and 3.42
Can use the transmission and gear calculator chart here: http://www.ringpinion.com/Calculators/Calc_RPM.aspx
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby chevymaher » August 4th 2013, 1:51am
It will be 5 MPH off @65 MPH.
You will be doing 5 MPH than the speedo says.
Exactly the opposite of what I got going on. Same 2 gears I went the other direction.
Topics: 91
Postby swharris [OP] » August 5th 2013, 8:23pm
Think there be any issues in the motor pulling that slightly taller gear?
swharris
Topics: 81
Images: 4
Alias (AKA): S4
Postby chevymaher » August 5th 2013, 8:30pm
Most vans have that gear factory.
Topics: 91
Postby xit » August 5th 2013, 8:42pm
Mine came with 3.42 gears but it is a 1994
Possibly Natures most perfect food, good beef jerky and cold beer......
xit
Years of Membership: xit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full yearsxit has been a member for 9 full years
Topics: 66
Images: 4
Extra Info: Conversion
Return to Rear-End
It is currently April 18th 2021, 4:13pm
Rear-End Forum
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 4:49pm
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 3:20pm
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
