Yet Another Request for Information
Postby ishort18 [OP] » August 9th 2013, 1:20am
hey guys,
i need to beg for info once again. sorry.
thanks in advance to whoever takes time out of their day to help me out. :ty:
hopefully going to be replacing the rear carrier and ring gear/pinion this weekend.
what i need is a complete parts breakdown. (assuming all of the seals, bearings, and other wear items are in need of being replaced)
i have the g80 carrier and old ring gear out of an s-10. and i will be ordering the new ring gear and matching pinion off of summit when i order the other parts i'll need.
here is my list of parts so far:
1.Carrier and Pinion Bearings-
http://www.summitracing.com/parts/rat-228b
2. Complete ring and pinion instal kit-
http://www.summitracing.com/parts/rmg-831044b
3.ring and pinon-
http://www.summitracing.com/parts/rmg-gm75410oe
i was told wheel bearings. but i was also told i need inner and outer wheel bearings but am not finding inner ones for the rear, just outer. also i am seeing 2 dif brands.
1. AutoExtra outer wheel bearings.
$18 a piece
http://www.summitracing.com/parts/axt-5 ... plications
2 Timken outer wheel bearings.
$42 a piece
http://www.summitracing.com/parts/tmk-5 ... odel/astro
i am worried because (2) is so much more than (1). is the price diff worth it? i dont wanna cheap out and get ****, but i dont wanna spend extra for no reason.
What else should i get?
again thanks in advance
1994 Chevy Astro Van aka "The DisasterVan"
105,xxx miles
4.3L (W)
RWD
ishort18
Years of Membership: ishort18 has been a member for 7 full yearsishort18 has been a member for 7 full yearsishort18 has been a member for 7 full yearsishort18 has been a member for 7 full yearsishort18 has been a member for 7 full yearsishort18 has been a member for 7 full yearsishort18 has been a member for 7 full years
Extra Info: 4.3L RWD Auto
  • Differential information
    by VANDAYUM » January 16th 2021, 12:41am in Rear-End
    January 16th 2021, 2:40am
    7
    14
    March 1st 2021, 5:33pm
Re: Yet Another Request for Information
Postby chevymaher » August 9th 2013, 1:42am
I would get bearing number 2 with the race on the axle. I paid 80 something bucks for my axle bearings. I just get the best if it a pain to take apart. I am sure the others are fine if you choose them tho.
There are only axle bearings at the end of the axle tubes. One on each side. Call them what you may but there are no inner and outer. Only the axle bearings. Period. And you need axle tube bearing seal seals. I don't see you having them listed.
Other than that your set it looks like.
Postby ishort18 [OP] » August 9th 2013, 2:11am
Thanks again chevymaher.
and the axel tube seals. i cant find anything by that exact name.
are these it tho, right?
http://www.summitracing.com/parts/tmk-4 ... /year/1994
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 2:13am
Yes they are the ones.
Postby ishort18 [OP] » August 9th 2013, 2:36am
are the axel seals going to be the same front and rear?
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 2:38am
ishort18 wrote:are the axel seals going to be the same front and rear?
There are 3 total. 2 axle seals. 1 on the pinion in front of the pumkin. Before the yoke goes in.
Postby ishort18 [OP] » August 9th 2013, 2:41am
i have a pinion seal on the list already, or are they different. an
d i meant are the front axel seals going to be the same as the ones on the rear?
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 2:47am
Front axle seals are in the rotors. you ain't doing them unless you getting new bearings and brakes. Front bearings just need re-packed with grease and re-torqued. They are practically indestructible with almost no maintenance.
Postby ishort18 [OP] » August 9th 2013, 2:50am
oh i got it. you said there is one for the pinion. is that the one that comes in the ring and pinion install kit (#2)
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 2:52am
Yes that be the critter
Postby ishort18 [OP] » August 9th 2013, 3:08am
ok thanks again..... one last question... then i am done.... promise haha.
i found what looks to be everything i need in one kit, and its much cheaper than all of the parts seperatly. plus its a richmond kit so they've gotta be good quality parts right?
this look like it'll work?
http://www.summitracing.com/parts/rmg-831044m
thanks a ton!
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 3:15am
The axle bearings are different. Everything but a astro/safari uses the same axle bearings.
Find that kit with out axle bearings and your set. That is what I used on mine was that set. And I had to get axle bearings and seals locally.
Richmond is the best quality you can get for this stuff.
Postby ishort18 [OP] » August 9th 2013, 3:31am
sweet! you are awesome.
found the kit
http://www.summitracing.com/parts/rmg-8310441
plus the pinion/ring gear
that should be all i need except fluid, wheel bearings, axel bearings, and axel seals.
edit* what weight gear oil? :ty:
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 3:34am
Yep except Gettin Er Done.
Postby ishort18 [OP] » August 9th 2013, 3:37am
what weight gear oil? and do i need the Limited slip additive?
105,xxx miles
4.3L (W)
RWD
ishort18
Postby chevymaher » August 9th 2013, 3:43am
90W gear oil unless your towing. Then higher number.
A G-80 don't have clutches in it so you don't need a additive.
Return to Rear-End
It is currently March 1st 2021, 5:33pm
Rear-End Forum
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
Attached by: MI_Ghost
MI_Ghost
in Rear-End
Comments: 21
Date: Jan 25 '21
Time: 7:22pm
SportsBoy
in Rear-End
Comments: 21
Date: Jan 21 '21
Time: 1:15am
