Leaking passenger rear end
Postby EddieDel84 [OP] » October 19th 2013, 4:39pm
Have a 01,RWD. Have a issue where the gear oil leaking thur the passenger seal. It gets on the brakes and tire. I have changed seals 4 different times from different stores. :evil: Change axle shaft. Notice its leaking again and pretty bad. :banghead: Does it sound like a new axle housing is needed and if so any suggestions on housing as all i find is used.
:ty:
EddieDel84
Years of Membership: EddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full yearsEddieDel84 has been a member for 7 full years
Van Model Year: 2001
Extra Info: LS 4.3l V6 RWD
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
    83
    February 25th 2021, 11:58am
Re: Leaking passenger rear end
Postby Drummernaut » October 20th 2013, 9:11am
I have always done bearings along with the seals "on both sides" if I find a leak. Bearings can easily be worn enough to cause this problem. Since you have already changed the axle, did you check the bearings?
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Postby EddieDel84 [OP] » October 20th 2013, 3:38pm
Yea I did do bearings as well. I'm clueless with this one.
EddieDel84
Postby RECox286 » October 20th 2013, 4:04pm
"Leaking passenger rear end" (???)
Consider putting a waterproof covering on the passenger seat before they get into
your truck. (Ha) I guess it depends on how much it's leaking...
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Drummernaut » October 20th 2013, 7:11pm
EddieDel84 wrote:Yea I did do bearings as well. I'm clueless with this one.
Can you determine if it is leaking from the seal or the housing around the seal? Your housing end(tube) could be damaged so you might have to try and straighten or use a sealant when pressing the seal back in. I can see how this can happen if the last guy to do the seal did not have the proper tools to remove the seal and bearing.
If it is leaking around the new axle, the only thing I can think of would be too much in/out play but even with that it should not leak and would be a whole other animal.
Unless this is break fluid. Not saying you would make that mistake but it has happened.
1999 Astro LT AWD
Drummernaut
Topics: 9
Return to Rear-End
It is currently February 25th 2021, 11:58am
Rear-End Forum
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
Attached by: MI_Ghost
MI_Ghost
in Rear-End
Comments: 21
Date: Jan 25 '21
Time: 7:22pm
SportsBoy
in Rear-End
Comments: 21
Date: Jan 21 '21
Time: 1:15am
