Loud metal clunk in front end
Postby maximumoverdrive123 [OP] » September 12th 2009, 10:36pm
2000 AWD Astro
Developed a very loud clunk, rather violent in that the both front wheels snap when the clunk occurs. Almost seems like something is preventing the rotation of an axle then it finally lets go, hence the snap and loud clunk. CV are in excellent shape no tears in the boots. This happens at walking speed, afraid to take it for a spin.
maximumoverdrive123
Years of Membership: maximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full yearsmaximumoverdrive123 has been a member for 11 full years
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
    9
    27
    November 24th 2020, 9:31am
Re: Loud metal clunk in front end
Postby ghostrider1061 » September 12th 2009, 11:18pm
how many miles do you have on the cv's? do you have rack and pinion or gear box sterring?
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby maximumoverdrive123 [OP] » September 12th 2009, 11:55pm
Found this technical service bulletin that seems to speak to the problem. The bulletin sounds if this condition is only for the rear end though?
Bulletin No.: 99-04-21-005B
Date: September, 2002
TECHNICAL
Subject:
Transfer Case Shudder
(Flush and Replace Transfer Case Fluid)
Models:
1999-2003 Chevrolet Astro (AWD)
1999-2003 GMC Safari (AWD)
1999-2001 Oldsmobile Bravada
with All-Wheel Drive (NV136) Transfer Case (RPO NP4)
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 99-04-21-005A (Section 04 - Driveline Axle).
Condition
Some customers may comment about a vibration (shudder) during tight turning maneuvers on dry pavement at vehicle speeds less than 8 km/h (5 mph).
Cause
This condition may be caused by a slip-stick of the clutch plates in the transfer case clutch pack. On 1999 and newer models, the preload that is designed into the clutch pack may contribute to the condition. In addition, contamination of the fluid may interfere with the friction modifiers.
Correction
Flush and replace the transfer case fluid on affected vehicles using the following procedure and the part number listed below.
Perform the following diagnosis prior to flushing and replacing the transfer case fluid in order to properly identify the shudder.
Diagnosis
1. Verify the shudder in the vehicle. The vehicle needs to be at operating temperature (driven at least 5 miles) for proper diagnosis. After the vehicle is at operating temperature, drive in a tight circle just short of steering wheel lock, at a speed less than 8 km/h (5 mph) in order to identify the shudder.
2. Identify what rear axle type the vehicle has.
^ If the vehicle has a standard rear axle, then proceed to step 3.
^ If the vehicle has a locking rear axle, remove the front propeller shaft. Refer to the Propeller Shaft subsection in the Service Manual. Drive the vehicle as outlined in step 1.
^ If the shudder goes away, install the front propeller shaft and proceed to step 3. Refer to the Propeller Shaft subsection in the Service Manual.
^ If the shudder does not go away, the locking rear axle may be the cause. Review the owner's records and determine if the rear axle was serviced at the first scheduled oil change. If records indicate that the axle service was done, then revaluate the condition using diagnostic information in the appropriate Service Manual. If the rear axle was not serviced, service the rear axle.
INFORM THE CUSTOMER THAT THE AXLE SERVICE IS AN OWNER'S MAINTENANCE ITEM NOT COVERED UNDER THE VEHICLE'S WARRANTY.
^ Install the front propeller shaft. Refer to the Propeller Shaft subsection in the Service Manual.
3. Flush the transfer case with the blue colored fluid (AUTO-TRAK II) using the procedure and part number listed below. Perform the flush procedure even if the transfer case contains the blue colored AUTO-TRAK II fluid in order to remove any possible contaminants. The AUTO-TRAK II fluid contains an improved friction modifier that should correct the slip-stick condition. Refer to the Transfer Case subsection in the Service Manual for information on draining and filling the transfer case.
Flush Procedure
Important :Refer to Corporate Bulletin Number 99-04-21-001, dated April 1999, for important information on removing the transfer case drain and fill plugs.
1. Drain the transfer case fluid.
2. Refill the transfer case with 2 L (2 qts) of new fluid, P/N 12378508 (Canadian P/N 10953626).
3. After refilling the transfer case, drive the vehicle a minimum of 8 km (5 mi).
4. With the transfer case at operating temperature, drain the transfer case fluid again.
5. Refill the transfer case with new fluid.
Important :The vehicle may require approximately 160 km (100 miles) of driving before the condition is completely corrected.
maximumoverdrive123
Postby astro355 » September 13th 2009, 2:05pm
RWD vans don't have a transfer case, that TSB is for AWD vans. When was the last time you changed the fluid in your transfer case?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby maximumoverdrive123 [OP] » September 13th 2009, 5:38pm
astro355 wrote:RWD vans don't have a transfer case, that TSB is for AWD vans. When was the last time you changed the fluid in your transfer case?
I've never had the fluid changed.
maximumoverdrive123
Postby astro355 » September 14th 2009, 8:52am
Ok then, I would follow the first recommended step of the TSB:
Correction
astro355
Postby maximumoverdrive123 [OP] » September 14th 2009, 11:27pm
Pulled the front left wheel and had a look at the CV joint. Seems the CV going into the transfer case has a vertical and horizontal movement. The catching and snapping sound appears to be comming from this area. Maybe the CV joint is shot? Very difficult to figure out where the noise is comming from. All U-Joints in good shape. Any one hear of problems inside the transfer case on these models or problems with the CV going into the transfer case?
maximumoverdrive123
Postby guyonearth » December 4th 2009, 11:19pm
Is the looseness in the joint itself, or in the transfer case bearing? There is normally a little play where the cv joints go into the housing, but it shouldn't be alot.
guyonearth
Years of Membership: guyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full years
Topics: 5
Alias (AKA): DeanC
Postby astro355 » December 5th 2009, 12:17am
I'd settle for an update sometime. :whistle:
astro355
Postby timelessbeing » December 5th 2009, 2:38am
I had the transfer case problem, and I'm pretty sure that only bumps in tight turns, not moving straight ahead. However I have a snapping too and it's from the control arms. Have someone listen to them or even feel the mounts while you turn the wheels all the way left and right.
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full yearstimelessbeing has been a member for 12 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Return to Rear-End
It is currently November 24th 2020, 9:31am
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
