rear end noise when turning corners
Postby bucktruck [OP] » January 10th 2014, 5:07am
I've got a 94 Astro EXT AWD. I was having an issue with what I thought was the rear-end knocking as I turned corners. So, I got a bone-yard rear end and planed to do a swap. I got my rear end out, and took the cover off to make sure I had the same gears, and noticed that my rear end looked better than the boneyard one I got. The oil looks clean, and there were no metal shavings or anything in it, and the axle seals aren't leaking at all, and there is very little play at the axles.
So, I'm afraid either it wasn't my rear end making the noise, and it something else, or, the boneyard rear-end I got is in just as bad of shape as mine and will have the same problems if I swap it out. I've had my van for about 3yrs and just started making the noise this summer. the van has about 140k miles on it.
Does anybody have any suggestions before I put either of these rear-ends back in the van and have the same problem?
Oh, its a non-posi, 2.73 rear end as well.
Thanks for any help.
bucktruck
Years of Membership: bucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full yearsbucktruck has been a member for 7 full years
Extra Info: AWD EXT
  • Little gas turning left and a pop
    by jmderyke » December 26th 2020, 6:41pm in Rear-End
    Last post by ptysiek View the latest post
    December 30th 2020, 11:06am
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
    20
    April 12th 2021, 5:01am
Re: rear end noise when turning corners
Postby WoodButcher » January 10th 2014, 5:27am
Use the better of the two even if it's the original and if you still hear the knock start looking for it again. Have someone else drive so you can find the noise. I've never known a rear axle to make a knock, look at the spring mounts and shocks, exhaust pipe and muffler. were the clamshells and U-bolts all good?
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby snapper388 » January 10th 2014, 7:17am
last time I had a popping noise while turning the tire store left the lug nuts loose.
snapper388
Years of Membership: snapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full yearssnapper388 has been a member for 7 full years
Images: 2
Extra Info: 4.3 Mark III 2wd
Postby bucktruck [OP] » January 10th 2014, 3:31pm
Now that you mention, the exhaust tailpipe was loose. I think I'm going to put my original one back in and see what happens. Guess I shouldn't have been so quick to assume it was the rear end. Might have saved myself a lot of trouble.
bucktruck
Extra Info: AWD EXT
Postby chevymaher » January 10th 2014, 4:43pm
Look at the shocks to. When the bushins go bad the shock smacks on the rear end.
Topics: 91
Postby bucktruck [OP] » October 2nd 2015, 8:17pm
I know this is now a few years old, but I thought I would post an update in case someone else is doing a search for the same problem.
It turned out it was the front U-joints. I put the original rear-end back in. Unfortunately, I couldn't get just the u-joints, I had to buy the whole drive shaft assembly, so it was about $500 to get it fixed. But, well worth it.
bucktruck
Extra Info: AWD EXT
Postby 97cargocrawler » October 2nd 2015, 8:51pm
*****! Thanks for letting us and future generations know.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Return to Rear-End
It is currently April 12th 2021, 5:01am
Rear-End Forum
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 4:49pm
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 3:20pm
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
