Rear Wheel Bearings Removal/Install
Postby romeroom [OP] » September 17th 2009, 6:45am
Looks like I'm going to have to replace the rear wheel bearings on my AWD '95 Astro.
Do any of you that have done this job have any tips? (links to pictures would be great). Some of the searching on this forum left me with more questions than answers.
Also, are there some specialty tools I absolutely need for this job?
Thanks.
'2002 Astro LS, AWD, 41k miles, "W" VIN
romeroom
Years of Membership: romeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full years
Topics: 38
Van Model Year: 2002
Extra Info: AWD 76000 miles
  • Ford 8.8 Eaton eLocker build and install
    by dit » August 2nd 2020, 5:50pm in Rear-End
    Last post by SainT View the latest post
    November 2nd 2020, 7:29am
  • Rear End Noise
    by Vernondo » August 12th 2020, 4:00pm in Rear-End
    Last post by Vernondo View the latest post
    August 13th 2020, 12:06am
    7
    22
    December 3rd 2020, 11:01am
Re: Rear Wheel Bearings Removal/Install
Postby Matrixx » September 18th 2009, 6:02am
Hi romeroom
It's a straight foward job rr. You will need an axle bearing puller/installer and an axle seal remover. You should be able to rent those locally I would imagine (local parts store).
If you have anymore questions just fire away, and I'm sure myself or others will do their best to help.:)
Matrixx
Return to Rear-End
It is currently December 3rd 2020, 11:01am
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
