Crack in rear axle housing near shock mount.
Postby JalosTA84 [OP] » October 12th 2009, 7:41pm
My parents' 1998 Astro recently developed a crack near the passenger side shock mount and has been leaking. It also seems the crack has been expanding slowly. When people are in the van, the crack widens a little bit. Can this crack be welded as a temporary or permanent solution?
Here are two pictures that show the crack (sorry for the low quality)
JalosTA84
Years of Membership: JalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full yearsJalosTA84 has been a member for 11 full years
  • Put in 2005 axle assembly on a 1999 Van?
    by Silver99 » November 2nd 2020, 3:42am in Rear-End
    Last post by SainT View the latest post
    November 4th 2020, 9:26pm
  • Remanufacture Rear End suppliers
    by rocketeer » November 13th 2020, 8:59pm in Rear-End
    November 14th 2020, 6:21pm
    80
    April 13th 2021, 2:27am
Re: Crack in rear axle housing near shock mount.
Postby dentprone » October 12th 2009, 9:00pm
Wild! I would drill a small hole at each end to relieve the stress, then weld up the crack carefully. Looks like the brake line would have to come off or get pushed aside to do the repair safely.
dentprone
Years of Membership: dentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full years
Postby astro355 » October 12th 2009, 11:58pm
You should also change the rear end grease too. You don't want any contaminates floating around in there. Any ideas how the crack started?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby JalosTA84 [OP] » October 13th 2009, 12:09am
Yikes! My mom used the van this morning to take my brother to school (less than 1 mile away) and the crack got larger. It is now half way around the whole tube. :screaming: :banghead: I think we need a replacement housing now. :( Not sure how the crack started, but there has been a weird grinding noise upon acceleration for the past couple of years that could not be diagnosed by a Chevy dealer. They said they even put in the rear end of another truck and the noise was still there.
smallSANY0008 (2).jpg (77.7 KiB) Viewed 1608 times
smallSANY0022 (2).jpg (126.13 KiB) Viewed 1608 times
JalosTA84
Postby dentprone » October 13th 2009, 1:29am
Aw man, that sucks......looking at those updated pics, I wouldn't attempt a repair. The rear end is going to have to come out anyway if you were to try and weld it with any peace of mind. Good luck on it, where abouts are you located?
dentprone
Postby JalosTA84 [OP] » October 13th 2009, 2:01am
dentprone wrote:Good luck on it, where abouts are you located?
In not-so-sunny-right-now Los Angeles, CA.
The differential was changed a couple of years ago and I think they put in a diff with the wrong ratio. We had not noticed that the speedo was showing a lower speed until this summer when my sister was pulled over for doing 85 on the I-10 in Arizona. She thought she was going 78. Didn't get a ticket though :) I verified with my cell phone (which has built-in GPS) and the speedo is slow by about 7-8 MPH. According to the RPO code list, the original ratio was 3.73. Could a change to 3.42 or 3.23 account for this speedo discrepancy?
Update:
I just used an online calculator and i came to the conclusion that it currently has a 3.42 ratio differential.
JalosTA84
Postby astro355 » October 13th 2009, 7:42am
Yeah, you should replace that rear end now. Unfortunately, you should park it until repairs can be made. Since that crack is growing, it will put (if not already) undo stress on the axle bearings and differential.
astro355
Postby Big_kid » October 13th 2009, 2:12pm
astro355 wrote:Yeah, you should replace that rear end now. Unfortunately, you should park it until repairs can be made. Since that crack is growing, it will put (if not already) undo stress on the axle bearings and differential.
X2 :hand:
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby dentprone » October 13th 2009, 4:19pm
Best of luck with the rear end, I have a line on a few, unfortunately I'm in FL. I'm sure you can find one easily out there. Keep us updated.
dentprone
Postby JalosTA84 [OP] » October 13th 2009, 11:31pm
I found a rear end from a 2001 Astro van with 67K miles and a 3.73 differential for $450. It has 90 day warranty. The seller is about 30 miles away and said he could bring it to us for free :)
JalosTA84
Postby tex star detail » October 13th 2009, 11:51pm
Try to talk him down some. I paid a little over $100 for mine, already pulled.
Is it already pulled? Who will you have install?
2000 GMC Safari Cargo
1999 Chevy Astro Cargo- SOLD Also
1995 GMC Safari Cargo- SOLD!
tex star detail
Years of Membership: tex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full years
Topics: 70
Extra Info: RWD Cargo
Postby JalosTA84 [OP] » October 14th 2009, 1:00am
Yea it is already pulled and ready to install. It is not an individual who is selling it, but a junk yard. I highly doubt I would be able to get a rear end in good condition and with warranty for the price you got yours in this area.
I was thinking we could maybe do the install ourselves but I do know a mechanic who lives a few houses down that we could probably pay to do it if we need to.
How complicated is it to do the install? There are 4 bolts that hold the axle housing to the frame, correct? Then we disconnect the driveshaft and brake lines? Remove the bottom shock bolts. Remove bolts from leaf spring mounts. Anything else?
JalosTA84
Postby tex star detail » October 14th 2009, 5:08am
Jack up rear of van, chock front wheels. Pull rear wheels
Put jack stands under the van. (on frame, not axle) The higher, the better.
Pull jack out.
Remove driveshaft. (tape the u-joints so caps don't fall off. Don't drop the shaft either) Set Aside
Remove 1 bolt on each shock BOTTOM. You can leave attached to the top.
Remove Emergency brake cable.
Remove Rear brake line. (1 line on top of diff.)
Put Jack under Differential and jack up a tad. Jack touching the diff.
Remove u bolts and bolts.
drop jack and slide rear end out.
Installation is backwards of removal.
I recommend replacing brake shoes and inspecting the drums. (turn or replace if necessary)
Also make sure you change the rear diff fluid.
Bleed the rear brakes. I recommend gravity bleeding. (make sure you lower the van down level and do not let the reservoir run low of fluid)
Someone else chime in if I forgot something.
tex star detail
Topics: 70
Postby astro355 » October 15th 2009, 7:23am
tex star detail wrote:Jack up rear of van, chock front wheels. Pull rear wheels
Pull jack out.
:goodpost:
Make sure you block off that brake line on the van side of the install. You don't want to bleed the master cylinder.
Also, PB Blaster will be your friend. Go and spray all of the bolts with this stuff immediately so it can soak in.
astro355
Postby JalosTA84 [OP] » October 18th 2009, 6:58am
We put in the replacement rear end today :) Thanks for all your ideas and suggestions. We still need to bleed the brakes, but everything else is done.
Something I noticed:
- The driver side parking brake cable has no way of being adjusted and it always has some tension. (or did I just completely miss it while looking for an adjustment?) The metal part that the cable hooks onto inside the drum seems to be constantly pushing on the small bar that connects the two brake shoes and it is not aligned with the secondary shoe at the location the small bar touches it.The passenger side secondary shoe and parking brake metal part are aligned and the parking brake cable did not have as much tension as the driver side parking brake.
Something I learned:
- In the process of putting in the new brake shoes, I initially put in two primary brake shoes on the drivers side. I could not get the drum to go on the axle. Spent a good 30 minutes looking at why it wouldn't fit :banghead: and then I saw that the two remaining brake shoes had less contact area. I took out the handy Hayne's manual and found out that there is a primary and secondary brake shoe. :thumbup:
JalosTA84
Postby dentprone » October 19th 2009, 3:52am
Excellent, glad to hear you got things back together so quickly. I don't know much about the parking brake cable question, guess I'll find out when I do my brakes.
dentprone
Postby JalosTA84 [OP] » October 20th 2009, 2:50am
Bah! I took the van out for a drive today and when I got back, I noticed that the differential housing was wet on the bottom and also that there was a splash on the gas tank of what appears to be the differential gear oil :eek: I think the oil is coming out through the front part where the driveshaft connects.
I think what I need is a new pinion seal. Is this something that I can put in myself or do I need special tools?
JalosTA84
Postby Big_kid » October 20th 2009, 2:25pm
I did a pinion seal on a Camaro once, it was a piece of cake. I've not looked at the Astro, but I'd imagine it's the same. Remove the drive shaft from the rear yoke, remove the yoke, carefully pull the old seal, a VERY thin bead of sealer on the outer edge of the new seal (or not, depends who you ask) tap it in flush, reassemble.
I learned my lesson a LONG time ago- if you have ANYTHING apart, replace the seal while it's accessible- even if it doesn't leak. When I was 18 I hand wrenched a transmission only to find the torque converter seal leaked like a sieve. Wasn't fun.
Topics: 185
Images: 344
Return to Rear-End
It is currently April 13th 2021, 2:27am
Rear-End Forum
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 4:49pm
Rockridge
in Rear-End
Date: Mar 14 '21
Time: 3:20pm
Attached by: SportsBoy
SportsBoy
in Rear-End
Comments: 21
Date: Feb 15 '21
Time: 3:03am
SportsBoy
in Rear-End
Comments: 21
Date: Feb 10 '21
Time: 11:44pm
SportsBoy
in Rear-End
Comments: 21
Date: Feb 08 '21
Time: 3:04pm
