-97ish AWD Astro front hub dimensions please
Postby Turbotarzan [OP] » February 24th 2014, 2:35pm
Does anyone know, or have a spindle or hub at hand they can measure, the 3-bolt pattern of the front hub from an AWD Chevy Astro? i.e the side that bolts to the spimdle.
I'd also like to know the center hole diametre needed to fit this hub in another spindle.
Looking to use Astro t-case to front diff to hubs in a roadster...
Cheers!
Turbotarzan
Years of Membership: Turbotarzan has been a member for 6 full yearsTurbotarzan has been a member for 6 full yearsTurbotarzan has been a member for 6 full yearsTurbotarzan has been a member for 6 full yearsTurbotarzan has been a member for 6 full yearsTurbotarzan has been a member for 6 full years
Alias (AKA): TT
Extra Info: AWD donor for rod
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
    52
    December 3rd 2020, 11:19am
Re: -97ish AWD Astro front hub dimensions please
Postby Turbotarzan [OP] » February 24th 2014, 7:00pm
Found it, or them actually. One sez 4.9 in., the other 5.0. Doesn't matter, I need 4.75:(
Turbotarzan
Alias (AKA): TT
Return to Rear-End
It is currently December 3rd 2020, 11:19am
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
cron
