2000 Safari AWD install g80 or posi?
Postby zaneroni [OP] » November 30th 2014, 2:02pm
Hi
I have been doing a lot of reading of different topics about adding limited slip to Astro's and to be honest I became more and more confused on which is the right product to buy.
What I understood so far is that g80 is GM code for the Eaton MLOCKER unit. When I read the product information on Eaton, M-Locker is a mechanical locking system not a positraction or lmited slip.
My question is which am I better off with, the Eaton M-Locker or Eaton Posi ? I live in Minnesota and my use for it will be in deep snow service and forest dirt roads. The AWD works okay until I have to tackle over 12 - 14 inches of snow. I onlt got it stuck once in 18 inch snow drift but luckily a truck passed by and was able to pull me out. I want to avoid that situation going forward.
Thank you
zaneroni
Years of Membership: zaneroni has been a member for 7 full yearszaneroni has been a member for 7 full yearszaneroni has been a member for 7 full yearszaneroni has been a member for 7 full yearszaneroni has been a member for 7 full yearszaneroni has been a member for 7 full yearszaneroni has been a member for 7 full years
  • Ford 8.8 Eaton eLocker build and install
    by dit » August 2nd 2020, 5:50pm in Rear-End
    Last post by SainT View the latest post
    November 2nd 2020, 7:29am
  • Drain Plug part number or size 2000 2wd
    by djcat » November 27th 2020, 4:22pm in Rear-End
    November 27th 2020, 8:38pm
    9
    73
    December 4th 2020, 7:07pm
Re: 2000 Safari AWD install g80 or posi?
Postby chevymaher » November 30th 2014, 3:14pm
The factory and the aftermarket Eaton posi's even tho they have the same name. Are completely different.
As for Eatons aftermarket posi's I own one of each. The limited slip and the detroit locker.
The detroit is what i got in the van. I like it alot. It is open untill it slips then it locks. Once you go sideways just let off the gas it unlocks and it returns to center quickly. As opposed to a limited slip with clutches which will remain engaged and the side to side action will continue.
So for traction in rain and snow I recommend the Detroit one for control. If you like to play more the other is more sideways longer. That is why it went in the chevelle. Posi is strictly to get side ways.
Factory posi wont engage if it spins to quickly. It is a lever action that locks and it isnt that strong. So if abused they rip in half easily.
Postby Astrofarian » November 30th 2014, 3:36pm
chevymaher wrote:The factory and the aftermarket Eaton posi's even tho they have the same name. Are completely different..........
There ARE upgrades for the factory units but more of a Band-Aid kinda thing, from what I've seen. Go with the aftermarket unit and you won't need to deal with any of this grief. :2:
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby zaneroni [OP] » November 30th 2014, 7:51pm
So what is the factory unit? is it the Mlocker by eaton or something else?
Thanks
zaneroni
Postby chevymaher » November 30th 2014, 8:17pm
zaneroni wrote:So what is the factory unit? is it the Mlocker by eaton or something else?
Thanks
G-80 option in a factory vehicle. It is a eaton locker.
Postby WDMICKJR » July 30th 2016, 1:32am
locker and LSD (: Limited Slip Differential) are not the same animal. The GM RPO code G80 is a LSD, not a locker.
SOLD 92 Astro CS with 95 4bolt 355 LT1, hand ported *374s & intake (David Vizard tech), EFI 24x, 211/219*, 1.94/1.6" 1.7"roller rockers .574"/.583", shift kit & corvette servo, G80, GT4, 255/70-15s, 2001LS1pcm; aka fAstro
WDMICKJR
Years of Membership: WDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full years
Topics: 27
Alias (AKA): Billy
Extra Info: 94 LT1
Postby chevymaher » July 30th 2016, 2:14am
WDMICKJR wrote:locker and LSD (: Limited Slip Differential) are not the same animal. The GM RPO code G80 is a LSD, not a locker.
The ones in the van are a odd critter actually. They have a hooked arm that locks. And breaks and rips apart if under enough stress.
Postby Leeann_93 » July 30th 2016, 4:06am
And this is the one in my '93 AWD Bravada, 3.73 with G80.
Postby Jeepster09 » July 30th 2016, 2:02pm
Ah....just like the "WALKING DEAD" the dead has been resurrected.
Jeepster09
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Jeepster09 has been a member for 4 full yearsJeepster09 has been a member for 4 full yearsJeepster09 has been a member for 4 full yearsJeepster09 has been a member for 4 full years
Extra Info: AWD Cargo
Postby Corsemoto » July 30th 2016, 7:02pm
This video explains the Astro G80 Eaton automatic locking differential pretty well. As you can seethe Astro G80 does use clutch packs behind the gear plates.
[youtube]tTGZOJQQBeE&feature=youtu.be[/youtube]
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby chevymaher » July 31st 2016, 2:09am
Got has both then.
Return to Rear-End
It is currently December 4th 2020, 7:07pm
Rear-End Forum
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 24
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 24
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 24
Date: Aug 06 '20
Time: 5:14pm
