2003 AWD safari - replace rear wheel hub
Postby SAFSTRO69 [OP] » September 26th 2015, 7:30pm
So is the AWD hub assembly an all in one deal or can I just replace the bearings? When I search for rear hub assembly for a 2003 all I get is hits for the front assembly. Can anyone help me out with a link? I have a bad scraping sound coming from the right rear wheel. I'm thinking bearings gone bad.
Cheers,
Birdo
Birdo
SAFSTRO69
Years of Membership: SAFSTRO69 has been a member for 5 full yearsSAFSTRO69 has been a member for 5 full yearsSAFSTRO69 has been a member for 5 full yearsSAFSTRO69 has been a member for 5 full yearsSAFSTRO69 has been a member for 5 full years
Alias (AKA): birdo
  • Is the Rear Axle Assembly different in AWD & 2WD?
    by josepheagle » September 13th 2020, 4:31am in Rear-End
    September 18th 2020, 12:11am
  • Rear end rebuild 1996 7.625
    by Astrolife » May 22nd 2020, 7:07am in Rear-End
    Last post by Astrolife View the latest post
    May 27th 2020, 10:01pm
    32
    October 27th 2020, 10:56am
Re: 2003 AWD safari - replace rear wheel hub
Postby chevymaher » September 26th 2015, 8:00pm
I don't have a link but. Take it apart and look first. Is it rusty? is the backing plate hitting because of rust? I have run into this quite a few times.
Postby Leeann_93 » September 27th 2015, 4:22am
Fronts are an all-in-one assembly. Rears are the same as RWD, just bearings and seals.
Postby SAFSTRO69 [OP] » September 27th 2015, 6:21pm
Great thanks, that makes sense. Relieved not $300+ for the rear. I shall take it apart and have a look. And hopefully clear up the issue.
Birdo
SAFSTRO69
Alias (AKA): birdo
Return to Rear-End
It is currently October 27th 2020, 10:56am
Rear-End Forum
dit
in Rear-End
Comments: 23
Date: Aug 28 '20
Time: 9:45pm
dit
in Rear-End
Comments: 23
Date: Aug 28 '20
Time: 9:29pm
dit
in Rear-End
Comments: 23
Date: Aug 07 '20
Time: 11:00pm
dit
in Rear-End
Comments: 23
Date: Aug 07 '20
Time: 4:01am
dit
in Rear-End
Comments: 23
Date: Aug 06 '20
Time: 5:14pm
