by cowboydan [OP] » February 21st 2011, 8:09pm
by a2l1 » February 21st 2011, 9:22pm
by cowboydan [OP] » February 22nd 2011, 2:20am
a2l1 wrote:You will want to look into acid based rust treatments. Rust mort is good and there are several others. There even some good quality paint that will cover and "stop" rust. be prepared to spend about 15-20+ bucks a quart for those good quality rust treatment paints POR 15 comes to mind.
by AstroCan » February 22nd 2011, 2:34am
by cowboydan [OP] » February 22nd 2011, 2:42am
AstroCan wrote:Well I fixed all the rust issues on mine last spring when I bought it. Under the doors, rockers, above the wheatherstripping (sliding door and driver/pass. door). So far only the rust on the rockers came back - most likely from the inside. Can't do much about it but spray some fluid film into the holes now and then.
by Gary » February 22nd 2011, 3:29am
by chevymaher » February 22nd 2011, 3:32am
by cowboydan [OP] » February 22nd 2011, 4:28am
chevymaher wrote:Cheap easy fix and it last years put fiberglass matt behind hole.Rub resin on outside bondo and paint.
if you do a good job rust sealed wont come back.
by chevymaher » February 22nd 2011, 4:37am
by cowboydan [OP] » February 22nd 2011, 5:33am
chevymaher wrote:Masking tape the angel hair cloth from back of hole.Mix resin and use gloves this stuff nasty.Hospital disposable type.Dab on resin on back till it clear only where it touches metal let it harden.Then gently with small brush put on remaining till it clear.Let harden.Then just cut shape you need in angel hair.Put on resin till clear and lay on out side of hole.Let harden then sand bondo.You will be amazed how tough it is.It tricky it stick to everything but what you want it to sometimes.Wish I could show you one time after that you have it down.It is a pain but it cheap and it last forever
by a2l1 » February 22nd 2011, 6:27am
by chevymaher » February 22nd 2011, 1:00pm
a2l1 wrote:If you plan on keeping the van for a long time the only sure way to remove the rust is to cut it away until you get to good clean metal then you can replace the missing metal any way you want. Best would be to weld in new panels and treat and prep them but you can always pop rivet them in. Thats not as sturdy but it works and lasts quite well. You can do fiberglass repairs to replace the missing metal as well. The fiberglass may need some re-enforcing depending on location and application but it works well. Dont forget vettes are made from fiberglass and even after twenty years the worst normally is some surface stress cracking/crazing. Those are the ways if you plan on keeping the van. I have seen vehicles where people wedged in some cardboard in the holes behind the rusty openings and just smeared bondo over that then sanded and painted. That normally lasts about six month to a year( if you are lucky) and then you have an even larger rust hole and more garbage to dig out before you can fix it. its all a matter of how long and how much ( how long do you want to keep the vehicle - how much do you want to spend) I have known people that just keep adding bondo its cheaper I agree but it seems like a waste of time to just keep doing it over and over, but it "works" for them.
by cowboydan [OP] » February 22nd 2011, 1:34pm
by chevymaher » February 22nd 2011, 1:38pm
by Leeann_93
» February 22nd 2011, 2:47pm
by cowboydan [OP] » February 22nd 2011, 3:18pm
It is currently April 14th 2021, 9:39pm
Exterior Forum |
Previous topic Next topic |
Sponsors |
