Dutch door will not open handle loose
Postby zipwood [OP] » December 28th 2016, 5:44am
2003 Safari rear Dutch door is shut and handle will not open. I thought I posted this but, could not find so here it goes again. First off Merry Christmas and all the best in 2017! My rear dutch door is closed and the handle seems to have disengaged from the linkage, ergo, the door will not open. The hatch opens just fine. I just want confirmation that I have to take off the inner cover to get at the linkage. Seems that this is the only way?
Thank you in advance.
zipwood
Years of Membership: zipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full yearszipwood has been a member for 5 full years
Images: 15
Extra Info: 4.3l V6 rwd
  • Dutch door handle part number?
    by Coyotecamper » September 7th 2020, 4:53am in Exterior
    Last post by Coyotecamper View the latest post
    September 7th 2020, 8:15pm
  • Fuel cap does not open
    by N6KB » July 22nd 2020, 5:44am in Exterior
    July 22nd 2020, 1:06pm
    42
    January 17th 2021, 10:37am
Re: Dutch door will not open handle loose
Postby juststartin » December 28th 2016, 5:54am
Yeppers, should be pretty obvious once you look inside.
03 Astro Cargo 4.3L RWD
I love Oscar the van....most of the time
juststartin
Years of Membership: juststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full yearsjuststartin has been a member for 9 full years
Topics: 9
Extra Info: cargo 4.3L RWD g80
Postby safariking » December 28th 2016, 6:04am
Not sure this video might help https://youtu.be/sOHjMopkXQw
safariking
Years of Membership: safariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full years
Topics: 23
Images: 9
Extra Info: SLE 4.3
Postby zipwood [OP] » December 28th 2016, 7:59am
Thanks for this. this is for the "hatch" my issue is with the dutch door. I do think I have to take the inside door skin off.
zipwood
Images: 15
Postby TurnNburn » December 28th 2016, 8:26am
Yes the door card needs to come off. Like juststartin said, once you have it opened up it should be pretty obvious. Don't worry if it's broken, that handle is like 10 bucks on Amazon. I just did mine. It's common. Especially when cold.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Astrofarian » December 28th 2016, 1:46pm
Another Astro with a broken door handle? This is extremely (and SADLY) common. Be sure to fish the busted pieces out of the bottom of the door cavity, you may even be able to rework/repair the handle so you have a spare. But for $10-15, order a new one for peace of mind.
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby zipwood [OP] » December 29th 2016, 7:08am
Fixed it! As I suspected the Actual DUTCH DOOR LATCH HANDLE was not broken (nor should it have been as it is only a year old). The linkage that connects the DOOR LATCH to the DOOR HANDLE had simply popped off. To fix this, I popped the top hatch, and was able to CAREFULLY POP off the inside door skin. I used a screw drive to pop the latch.
Opened the door, removed the 4 screws that hold the HANDLE ACCESS COVER. Then I reconnected the linkage. This set up is kind of dumb, it really needs a PRESURE FIT "washer" to hold that linkage better into the handle. Hopefully it will not pop out again anytime soon. I also sprayed a bunch of lube all over everything. If this fails again, I will try to find a pressure fit cotter washer, or maybe even attempt to drill a small hole and insert an actual cotter pin, or I will just use what most of you use: Duct Tape :D
The images show the linkage 1) Not Inserted and 2) Inserted Note: the white Nylon pressure fit and how easily the linkage can pop out.
63522
63514
Hop this helps someone with this simple issue.
zipwood
Images: 15
Postby Astrofarian » December 29th 2016, 7:53am
Glad I was wrong....and of course, glad to hear you got it fixed!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Postby zipwood [OP] » March 13th 2017, 7:35am
Well it is March 2017 and just an update on the DUTCH DOOR LINKAGE ISSUE. FYI that linkage just pressure fits into a nylon seat. There is no cotter pin or anything. So of course what happened once happened again, the linkage popped out. The only real quick fix was a whack of duct tape. Uggg! But whatever it works. I think the "aftermarket" handle is a bit off spec or my the linkage itself has worn a bit. I guess his is what one can expect with a Vehicle that has about 435,000 km on and a back door that has opened probably 10,000 times. All the best
zipwood
Images: 15
Return to Exterior
It is currently January 17th 2021, 10:37am
Exterior Forum
VincentVanGo_M
in Exterior
Date: Today
Time: 1:19am
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
