Crack found behind door hinge
Postby scott936 [OP] » April 13th 2011, 1:52am
After replaceing the pins and bushings and still have major drop when the door opens I did some deeper looking and found a 2 1/2 inch long crack on the back side of the upper hinge. Sorry I did take any picks of the crack just the repair.
Image[url=https://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=27095]Image[/url
2002 Astro Van Cargo
Air Bags
Yokohama 225/60 17
Overhead console from 92 S 10
Custom Rear Bumper
Custom front seats
scott936
Years of Membership: scott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full years
Topics: 37
Images: 20
Van Model Year: 2002
Extra Info: 2 WD Cargo
  • Dutch door handle part number?
    by Coyotecamper » September 7th 2020, 4:53am in Exterior
    Last post by Coyotecamper View the latest post
    September 7th 2020, 8:15pm
  • 1994 Safari Exterior Fuel Door
    by edwina » September 13th 2020, 5:04pm in Exterior
    September 14th 2020, 3:18am
    March 5th 2021, 2:21pm
Re: Crack found behind door hinge
Postby chevymaher » April 13th 2011, 2:27am
My door has a slight sag in drivers.Nothing bad just enough to notice.Well I read your post and immediately went and checked my door.Whew just a little slop in the top pin.you had me going there.I a worry wort when it comes to my toys.Good job fixing yours .
Postby cowboydan » April 16th 2011, 1:25am
both my doors sag a bit. these doors are heavy!
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
Postby scott936 [OP] » April 16th 2011, 1:46am
cowboydan wrote:both my doors sag a bit. these doors are heavy!
Heavy, try a 70 Monte Carlo :rofl:
The biggest problem I had was not being able to build any support on the back side of the hinge, just had to hope the penetration was deep enough to bond the OEM support and not burn the exterior paint.... Weld was layered to build a bridge in hopes that it will never crack again, if it does I will need a door.
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Postby tedanderson » April 16th 2011, 4:29am
When I saw the title of the thread, my first thought was, "Oh my! Was the PO a crackhead? Was he so into his addiction that he somehow got it behind the door hinge?"
Anyhow, I think that this is somewhat common on our vans. Mine is cracked also and on a few other vans that I've seen with a sagging door had problems with the pins and bushings but also had a crack behind the hinge as a result.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby scott936 [OP] » April 16th 2011, 11:03am
tedanderson wrote:When I saw the title of the thread, my first thought was, "Oh my! Was the PO a crackhead? Was he so into his addiction that he somehow got it behind the door hinge?"
I agree, I think is a design flaw, the problem is the fix. The door steel is so thin to support the weight the only choice is to make the weld huge in hopes that it will disperse the weight over a larger surface area.. We'll see!!
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Postby Leeann_93 » April 16th 2011, 4:07pm
Try the 70's 2-door Lincolns.... :o
Postby cowboydan » April 17th 2011, 3:21am
how about a 76 dodge monaco coupe. them old cars ..i tell ya
cowboydan
Topics: 67
Alias (AKA): cbd
Postby scott936 [OP] » April 17th 2011, 11:26am
Back then you had to park 6 feet away form someone just to open the door, don't get me started if you got your fingers caught in the door when shutting them...... A little pain clears the mind, mine is still clear from those days..
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Postby chevymaher » April 17th 2011, 12:13pm
scott936 wrote:Back then you had to park 6 feet away form someone just to open the door, don't get me started if you got your fingers caught in the door when shutting them...... A little pain clears the mind, mine is still clear from those days..
And dont forget back in that dinosaur tech days.A simple pack of 50 cent washers between the door and hinge ajusted and worked like new.Many a camaro I got cheap because the door dropped 2 inches when it opened from people sitting on it open.50 cents and 10 minutes work,no cracks ever tho.
Postby scott936 [OP] » April 17th 2011, 6:22pm
Amen brother :dance:
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Return to Exterior
It is currently March 5th 2021, 2:21pm
Exterior Forum
Olivier02
in Exterior
Date: Mar 02 '21
Time: 2:48am
in Exterior
Comments: 13
Date: Feb 28 '21
Time: 4:18am
AstroOafAdventurerAstroOafAdventurer is online!
in Exterior
Comments: 13
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
