sliding door roller
sliding door roller
Postby duranged_rt [OP] » May 1st 2011, 6:20pm
alright so, my father in law gave me a 95 safari for free. my durango get 7.5 mpg so he thought i might need than van to save some money. the sliding door has the dreaded center roller prob. this thing is shot. the van is a rockwood conversion and is in pretty decent shape just some minor work to do. i have thought about just knocking out the pin the door will close all the way but have only had the thing since saturday evening. just long enough to dump some gas in it and plate the thing. i need to know if anyone has replaced the center roller and where they got the part. mine is welded in so im assuming i can knock out the pin and replace. just need to know where to get the roller side. any help would be great!
thanks ed
duranged_rt
Years of Membership: duranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full yearsduranged_rt has been a member for 9 full years
  • Door Roller Replacement?
    by WinnieVan » October 28th 2020, 8:45pm in Exterior
    Last post by WinnieVan View the latest post
    November 3rd 2020, 12:10pm
  • Pin removal on door roller.
    by Amnesia Wes » March 21st 2021, 1:01am in Exterior
    Last post by icebrrg3rd View the latest post
    March 21st 2021, 6:28pm
    68
    April 11th 2021, 10:35am
Re: sliding door roller
Postby RECox286 » May 1st 2011, 8:44pm
My suggestion would be to scour the JY's for a good assy, and just swap. It's an easy, cheap solution.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby a2l1 » May 2nd 2011, 4:57am
I never replaced the rollers when mine were bad and the operation of the slider was a problem. I removed the slider cover plate on the outside of the van. and with a pry bar I bent the lower lip of the channel up all along the side channel then replaced the cover. It has been several months now and I have had not a single issue with it. The slider works fine no hang ups or any problem. May not be the the best solution but is was easy and inexpensive, cost $0 and I was able to lube the entire channel as well.
A J
1995 Regency conversion really a work in progress !!
Hernando County - West Central Florida
a2l1
Years of Membership: a2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full yearsa2l1 has been a member for 10 full years
Topics: 73
Alias (AKA): A J
Extra Info: 4.3-auto-RWD
Postby duranged_rt [OP] » May 2nd 2011, 4:06pm
well the rollers are almost completely gone. the plastic bushings are all but gone too. ive thought about removing them and bending the track but would rather do it the right way. may hit a jy before weeks end.
duranged_rt
Postby duranged_rt [OP] » May 12th 2011, 3:17pm
alrighty so heres how it goes. 45 minute job. its fixed and works great.
1. removed 3 torx holding door latch. dont worry it wont fall in.
2. prop door up. i did it with my foot.
3. squeeze pin lock in middle of pin. tap pin out with hammer.
4. slide roller to corner. mine was off but.....
5. shut door.
total 5 minutes tops.
6. drive to junk yard 10 minutes.
7. do 1 - 5 again. 5 minutes.
8. pay my $5 for part. yeah, $5. could have gotten a foot long, but i need door fixed.
9. drive home 10 minutes.
total 25 minutes. plus listening to larry, daryll, and daryll gab, but that doesnt count.
10. clean and lube the heck out of old part.
11. open door and prop with foot.
12. slide part in at corner.
13. align pin and tap in with hammer.
14. put in 3 torx. done!
total 5 minutes again
15. clean and lube the rest of tracks; top, bottom, and middle.
total 10 minutes.
total time 45 minutes or so. slides like a champ now!
duranged_rt
Postby Bis » May 24th 2011, 3:08am
This may not be a deal-breaker but your forgot to list the time it took you to do:
:mrgreen:
Thanks for the run-down Duranged
✔ Recovering 3-Time ex-Aerostar owner since 1996.
✔ RC Hobbyist and Dance music nut.
✔ Geeky Astroholic.
ツ Glad to be of help! ツ
Bis
Years of Membership: Bis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full years
Topics: 30
Alias (AKA): Bis
Extra Info: LS 4.3L V6 RWD
Return to Exterior
It is currently April 11th 2021, 10:35am
Exterior Forum
Attached by: Godron629
Godron629
in Exterior
Comments: 20
Date: Apr 05 '21
Time: 4:46pm
in Exterior
Date: Apr 02 '21
Time: 4:50pm
Bigforkg
in Exterior
Comments: 0
Date: Mar 26 '21
Time: 1:05am
Tanino
in Exterior
Date: Mar 23 '21
Time: 11:51am
Tanino
in Exterior
Date: Mar 23 '21
Time: 3:10am
