bought me some of this
took of the seal and two end pieces, cleaned,degreased,and removed old silicone I previously used. Followed some instructions I found online on how to apply this adhesive. Before removing the seal I marked the position of the gasket as it laid on the van. Re installed the now cleaned and glued gasket to the van.
drilled 1/4" holes at each corner to aid in draining of said corners.
Checked the seals around the actual doors, they look good. I did find a small part of the gasket on the driver side that had come off, but I was able to push the little clips back into position and the seal back into place.
I am wondering if the two end pieces of the glass seal are still available, mine are like sponges and kinda beat up,lol
Have I missed anything???
