Need help with roof rack?! Previous owner removed side rails
Postby HeatherWhatever [OP] » July 25th 2017, 9:15pm
Hi! I'm new here & also a new Astro van owner. I really need a roof rack since I'm doing the whole vanlife thing, but the previous owner removed the side rails. Can I get these from a pick & pull? How do I know which ones to get? I'm so clueless
HeatherWhatever
Years of Membership: HeatherWhatever has been a member for 3 full yearsHeatherWhatever has been a member for 3 full yearsHeatherWhatever has been a member for 3 full years
Alias (AKA): Heather
Van Model Year: 1996
Extra Info: AWD passenger van
  • Dealing with the sins of the previous owner
    by Wokka » July 21st 2020, 1:38am in Exterior
    Last post by Wokka View the latest post
    August 27th 2020, 9:05am
  • Any Issue With Using L-Track as Roof Rails ?
    by SportsBoy » July 24th 2020, 12:44am in Exterior
    August 6th 2020, 2:42am
    September 23rd 2020, 1:14pm
Re: Need help with roof rack?! Previous owner removed side r
Postby Astrofarian » July 26th 2017, 3:37am
Hi and welcome, Heather. Your profile says you have a 96 AWD....I'm not aware of any "96 only" roof rack options so you're in luck. Unless I'm wrong, the roof rack and parts thereof never changed on the entire run of EXTENDED vans so anything 96-2005 should fit. Pre-96, you MAY (Don't quote me on this) find donor parts on earlier vans.
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby WinnieVan » July 26th 2017, 4:59am
Are you sure your van had a roof rack? Are there holes in the roof where it existed previously? There are a lot of vans that did not come with a roof rack at all!
You can remove one from one in a junk yard -- might be worth grabbing a couple extra crossbars while you there too. I'd assume anything 95 and greater would suffice. Maybe even a GEN-I Extended version would have the same rack, but I'm sure you'll be able to find a 95+ one with a rack in the JY eventually.
I had to pull my roof rack off recently for my solar install -- it involved removing and reinstalling the headliner. In other words, it's also a great time to add some insulation to the roof!!
If there are no pre-existing holes, you may want to consider an aftermarket rack -- they are a bit more robust (I think).
Also -- my roof rack hardware was pretty rusted out, so might want to consider new bolts too.
WinnieVan
Firing on 2 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full years
Topics: 61
Images: 27
Postby WimpTech » July 26th 2017, 2:49pm
^^^ That
Welcome Heather
WimpTech
Firing on 3 Cylinders (L5)
Years of Membership: WimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full years
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Return to Exterior
It is currently September 23rd 2020, 1:14pm
Exterior Forum
TaninoTanino is online!
in Exterior
Comments: 21
Date: Today
Time: 12:40am
Bigforkg
in Exterior
Comments: 21
Time: 1:30am
SoccerMom4x4
in Exterior
Comments: 21
Date: Sep 21 '20
Time: 3:15am
in Exterior
Comments: 21
Date: Sep 20 '20
Time: 11:44am
SoccerMom4x4
in Exterior
Comments: 21
Date: Sep 17 '20
Time: 3:25am
