Tubular step sides?
Tubular step sides?
Postby JoshLudlow [OP] » January 18th 2018, 4:50pm
Greetings friend,
I searched the threads for this topic and came up empty. I'm looking to put some tubular step sides on my safari, I took off the steps that came stock because they were cracked and broken beyond repair but I have several small children and a tiny wife that needs the leg up, especially after I do the suspension lift and tire mods. Anyone done anything similar or know some that wouldn't be too hard to install, I do not have a welder yet, so something that I can bolt on would be awesome, but I am open to ideas. Thanks for your time.
Outlaw 6 Delta out.
Outlaw Six Delta out.
JoshLudlow
Years of Membership: JoshLudlow has been a member for 2 full yearsJoshLudlow has been a member for 2 full years
Images: 6
Alias (AKA): Outlaw6D
Re: Tubular step sides?
Postby MmusicmanMmusicman is online! » January 18th 2018, 4:58pm
I'm a little curious too... :D
Firing on 5 Cylinders (L5)
Topics: 71
Images: 49
Postby Captn.Crunch » January 18th 2018, 7:16pm
I have a set of 67” rock sliders I’ll be putting on mine. I plan on running a piece of rectangular steel tube 2”x 3” Maybe? from the front rear spring hanger to the front clip. The tube will be drilled and use existing bolts. Then drill, tap and bolt the rock sliders to the tube stock. Haven’t done it yet cause it’s winter time in New England but is should be a bolt on senario. If that mounts too high to use as a step, use different sized rectangular stick to lower your mounting points
99 GMC Safari SLE AWD
2" body lift
S-10 rear leafs
NP236 tc
Detroit Truetrac Torsen rear diff w/3.73's
MFactory Torsen equipped front diff-iron
Soon:
Skid plates
rock rails
Captn.Crunch
Years of Membership: Captn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full years
Topics: 21
Images: 4
Extra Info: 4x4 TwinTorsen diffs
Postby WimpTech » January 18th 2018, 7:31pm
Mmusicman wrote:I'm a little curious too... :D
...heard that about ya!
:whistle:
Replacements from the JY maybe???
WimpTech
Firing on 3 Cylinders (L5)
Years of Membership: WimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full years
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby markmitch » January 18th 2018, 9:19pm
What I would do and may do as I get older, I would measure the rockers of my van then go to a local auto salvage yard and measure trucks they make them for to find the closest match then order some for said vehicle and either make my own brackets or have a welding shop make them for me.
Firing on 4 Cylinders (L6)
Topics: 595
Images: 20
Extra Info: RS V8
Postby MI_Ghost » January 18th 2018, 10:10pm
The rockers are 72" in length.
I believe the Silverado extended cab has the same length between wheelwells.
Make mounting brackets that bolt to the stock running board mounting points. Look at the frame rails for the thread holes.
The astro can be lifted by the side with the factory running boards. No problems with supporting the weight.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Years of Membership: MI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full yearsMI_Ghost has been a member for 4 full years
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby MI_Ghost » January 18th 2018, 10:19pm
JoshLudlow wrote:I took off the steps that came stock because they were cracked and broken beyond repair
If you do not use the original mounting brackets. I need a 3rd bracket from the front.
Let me know if you have one you can spare.
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Postby 97cargocrawler » January 19th 2018, 12:19am
They would be totally tubular if there was a frame to bolt them to. With a truly tiny wife and children you could easily get away with those truck steps that bolt to the rocker panels. The "Bully" brand claim to support upwards of 350lbs but I can attest that is pure **** when bolted to the rockers with their brackets. But for 125lbs or less I think they would work just fine.
Much easier than trying to fab something to hold pipes.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Rinny » January 19th 2018, 2:04am
I am in the process of getting the length on these rock sliders. I was looking at a 2018 chevy Colorado ZR2 and these are the rock sliders that come on it from the factory. I like them a lot and if they are the correct length or can be an easy mod to make them fit it will be an added mod on my build.
https://www.4wheelparts.com/Armor-Prote ... _Container
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
Postby MI_Ghost » January 19th 2018, 2:45am
Rinny wrote:I am in the process of getting the length on this rock sliders.
Those are cab length so probably only about 50" long.
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Postby JoshLudlow [OP] » January 19th 2018, 3:43pm
I actually have one in the back right now I can totally send it to you just pm or call me
Express Auto Care and U-Haul
(260) 637-0711 ask for Josh
JoshLudlow
Images: 6
Postby JoshLudlow [OP] » January 19th 2018, 3:45pm
97cargocrawler wrote:They would be totally tubular if there was a frame to bolt them to. With a truly tiny wife and children you could easily get away with those truck steps that bolt to the rocker panels. The "Bully" brand claim to support upwards of 350lbs but I can attest that is pure **** when bolted to the rockers with their brackets. But for 125lbs or less I think they would work just fine.
I'm the biggest one in my fam, and I'm about 240lbs, that might be a viable solution for the drivers side but need something longer for pass side to cover the slider
JoshLudlow
Images: 6
Postby ronaldperu » January 20th 2018, 2:23am
ronaldperu
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: ronaldperu has been a member for 6 full yearsronaldperu has been a member for 6 full yearsronaldperu has been a member for 6 full yearsronaldperu has been a member for 6 full yearsronaldperu has been a member for 6 full yearsronaldperu has been a member for 6 full years
Topics: 10
Images: 43
Alias (AKA): ROJO
Van Model Year: 1996
Extra Info: ls
Return to Exterior
It is currently September 21st 2020, 8:17pm
Exterior Forum
SoccerMom4x4
in Exterior
Date: Today
Time: 3:15am
Tanino
in Exterior
Time: 11:44am
SoccerMom4x4
in Exterior
Date: Sep 17 '20
Time: 3:25am
Sailing_Faith
in Exterior
Comments: 20
Date: Sep 11 '20
Time: 6:13am
hippovan
in Exterior
Comments: 0
Date: Sep 10 '20
Time: 11:26pm
Users browsing this forum: No registered users and 17 guests
