I have a loaded 2WD 1986 short Astro w/4.3 L owned since new and 335,000 mi on the clock...repowered and trans done at 210,000.Towing package, 3.73 posi rear, F-R A/C, factory alloys, P/S, P/B etc. etc.(I still have the build sheet and window sticker, and the original keys!)
Everything still works properly except the power door locks. Fronts are "sluggish" and don't always lock when you hit the "LOCK" switch on the driver door. Side and rears are INOP. Any suggestions on where to start looking? Was thinking bad ground, broken wire, bad contact(s) somewhere. Been this way for some time...project for this winter. Recently cleaned battery terminals so no problem there.
Somebody on this must must have debugged this problem before. Any suggestions/advice appreciated. Thanks!
PS also have a 2004 AWD ASTRO long body with "everything" GM NEVER SHOULD HAVE STOPPED MAKING THESE!
