Window motor making horrible grinding, crushing sounds
Postby lightimages [OP] » May 24th 2018, 7:10am
Driver window goes up and down in jerks, but sounds like something breaking inside the door.
Any ideas for probable cause?
lightimages
Years of Membership: lightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full yearslightimages has been a member for 8 full years
Van Model Year: 2001
Extra Info: LT 4.3L V6 RWD
  • Power Window Motor Spins, Window Won't Move
    by BillyJoBob » January 24th 2021, 8:54pm in Exterior
    January 26th 2021, 2:17am
  • Sliding door window not tight to seal
    by AstroOafAdventurer » December 15th 2020, 4:22am in Exterior
    January 14th 2021, 9:42pm
    68
    February 28th 2021, 10:27pm
Re: Window motor making horrible grinding, crushing sounds
Postby chevymaher » May 24th 2018, 8:11am
Take the door panel off and see if it needs greased. The track parts.
Postby nonhog » May 24th 2018, 1:51pm
When my motor went bad I also found the track was off. Maybe 2 separate problems? But like Chevy said you need to pull the door panel. Good luck!
Recovering hoarder
My Slow build..... viewtopic.php?f=127&t=107426
nonhog
Firing on 7 Cylinders (L1)
Years of Membership: nonhog has been a member for 4 full yearsnonhog has been a member for 4 full yearsnonhog has been a member for 4 full yearsnonhog has been a member for 4 full years
Topics: 37
Images: 16
Van Model Year: 1996
Postby lightimages [OP] » May 26th 2018, 7:50pm
nonhog wrote:When my motor went bad I also found the track was off. Maybe 2 separate problems? But like Chevy said you need to pull the door panel. Good luck!
I think I have found the problem - broken worm drive in the window motor.
Thanks
lightimages
Return to Exterior
It is currently February 28th 2021, 10:27pm
Exterior Forum
in Exterior
Date: Today
Time: 4:18am
AstroOafAdventurer
in Exterior
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
Attached by: Allergictostabwounds
in Exterior
Date: Feb 16 '21
Time: 10:10pm
Users browsing this forum: icebrrg3rdicebrrg3rd is online!, MI_GhostMI_Ghost is online! and 11 guests
