Roof rack for gutterless roof
Postby VanDamn [OP] » July 31st 2018, 10:25pm
My 2004 safari has a gutter less roof and my research for "gutter less roof rack" is only returning bolt-on options, is that a good idea? If not, what are my options?
Most car people I've asked say "don't drill into the roof", but I also see people this site doing it, so I'd assume you're probably doing it right and not having leaks/issues.
In that case: how do you do it and still stop leaks/etc?
VanDamn
Years of Membership: VanDamn has been a member for 2 full yearsVanDamn has been a member for 2 full years
  • Astro, '95 roof rack on '04?
    by bradaskins » May 27th 2020, 11:57pm in Exterior
    June 4th 2020, 1:33am
  • REMOVING ONLY THE CROSSBARS FROM THE ROOF RACK?
    by Rein » June 12th 2020, 4:00pm in Exterior
    June 19th 2020, 11:18pm
    7
    17
    October 30th 2020, 9:06am
Re: Roof rack for gutterless roof
Postby TurnNburn » July 31st 2018, 10:39pm
I drilled holes into my roof, that's the only way to get it done.
Copious amounts of silicone on both sides
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby VanDamn [OP] » July 31st 2018, 11:05pm
What are the absolute do's/don't's of the install? You've never had issues with leaks?
VanDamn
Postby TurnNburn » July 31st 2018, 11:35pm
No, no leaks. Just watch what you are drilling into and you will be fine. silicone on both surfaces of the roof when installing whatever you have planned. pretty hard to mess up.
just make sure its on straight for Christ sake. there is a van rolling around town that its installed not even close to straight and it drives me bonkers every time I see it.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby Wiley » August 1st 2018, 1:32am
I too drilled and have been ok, no leaks. I also managed to hit the ribs just where I was aiming so the washers fit into the indent. Must have been pure luck cause while I prefer DIY, it is usually DIY Redneck style. Measured 10 times and then closed my eyes. :eek:
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Postby Rockridge » August 1st 2018, 2:44am
I have a rack in the works and will be drilling into the roof. I have been meaning to measure the rack support locations on my other van so I know where to drill. I can post up the factory hole locations tomorrow if that would help you out.
Rockridge
Firing on 8 Cylinders (L1)
Years of Membership: Rockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full years
Topics: 46
Alias (AKA): Walker
Postby WinnieVan » August 3rd 2018, 5:15am
TurnNburn wrote:just make sure its on straight for Christ sake. there is a van rolling around town that its installed not even close to straight and it drives me bonkers every time I see it.
You can probably sense my OCD from here. That'd make me crazy.
WinnieVan
Firing on 2 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full years
Topics: 62
Images: 27
Postby Rockridge » August 3rd 2018, 2:15pm
I hooked my tape measure to the rear roof/ hatch area.
Factory bolts are at:
5-1/2"
9-3/4"
36"
39-1/2"
61-1/4"
64-7/8"
84-7/8"
89"
Rockridge
Topics: 46
Alias (AKA): Walker
Postby markmitch » August 3rd 2018, 2:49pm
I put my rack on the roof marked the location then made sure the rack in strait, I drilled the holes then took 2x2 sections of plate steel drilled them put silicone on top and bottom of holes in roof added a small o ring to all bolts put the bolts through roof rack then the roof put 2x2 sections of steel on bottom of roof then added washers and nuts. van was in yard for a year while I was doing suspension and brakes mods and we had a heavy rain season and I did not have any leaks. Markmitch
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby nosxjeep » August 3rd 2018, 6:28pm
I recently made measurements, but wasn't really focused on the roof rack mounts, though they are in there:
96382
The center of each of those cross members might be a good thing to aim for.
96370
Careful for wiring in the B and C pillar.
nosxjeep
Years of Membership: nosxjeep has been a member for 3 full yearsnosxjeep has been a member for 3 full yearsnosxjeep has been a member for 3 full years
Images: 21
Alias (AKA): NoS
Extra Info: LS AWD 3+1 30s
Return to Exterior
It is currently October 30th 2020, 9:06am
Exterior Forum
Attached by: WinnieVan
WinnieVan
in Exterior
Date: Oct 28 '20
Time: 9:09pm
WinnieVan
in Exterior
Date: Oct 28 '20
Time: 8:43pm
stentstent is online!
in Exterior
Comments: 19
Date: Oct 27 '20
Time: 3:37pm
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
