by 95AstroLT [OP] » December 7th 2018, 12:46am
by WoodButcher » December 7th 2018, 1:43pm
by WoodButcher » December 7th 2018, 1:57pm
by Coaster » December 7th 2018, 2:10pm
by sixsix » December 7th 2018, 2:41pm
Coaster wrote:its glue. its a thing now
by WoodButcher » December 8th 2018, 2:51am
by smokinjoe » December 8th 2018, 4:47am
by 90safari » December 8th 2018, 6:10am
by astrometalvan » December 8th 2018, 1:11pm
by AstroWill » December 8th 2018, 9:00pm
by MechBob » December 9th 2018, 12:16am
by 95AstroLT [OP] » December 9th 2018, 5:24am
MechBob wrote:Astro front door hinges have no "backing plate",there is merely 3 layers of thin sheet metal,not fully welded,but spot welded at the spot welds you can see in the hinges,and spot welded in other places(GM saving money). Replacement hinges come with a threaded backing plate,for use after you drill and chisel off the old hinge.If you are going to keep the van,you should pull door,drill through the hing and layers,and put in a bolt,washer nut,washer on the inside.But,you could use a nut with a made in washer,as you might have to weld it to a wire,to get it up there,through the lower access hole,unless the newer vans have an upper access hole?IDK.Just 1 bolt pinching all the layers would make a huge difference.Also,body shops have been known to cut an access hole to get to the inside of the hinge area,but be sure to seal it,to keep mice out.
by 95AstroLT [OP] » December 9th 2018, 5:33am
AstroWill wrote:I would get it cleaned up and welded. I also wouldn't use the door as a crutch to get in/out of the van, seen that cause problems before.
by 95AstroLT [OP] » December 9th 2018, 5:37am
astrometalvan wrote:Maybe a toggle bolt like the ones that hold a microwave oven to the wall would work?
Drill the hole from the front, squeeze the toggle and pop it in and tighten up the bolt.
by Leeann_93 » December 9th 2018, 4:37pm
95AstroLT wrote:Dear wife mistakenly thought the bar above the passenger's side air bag was a passenger assist. Fortunately she quit pulling when she heard plastic cracking so it's still there with only minor damage. Have a replacement from local JY, but had to seriously hurt the dash to get it out of the donor van.
by WoodButcher » December 10th 2018, 12:06am
It is currently March 7th 2021, 1:43pm
Exterior Forum |
Previous topic Next topic |
Sponsors |
