Hoping someone can help...
I have a 2000 GMC Safari, and I recently changed out my front door lock actuators. That was an interesting situation, because the previous owner or seller had done some rigging with universal 2 for $10 plastic replacements. Instead of taking the old ones out and putting the new ones in the proper spot, this person stuffed them behind the arm rests and attached it's universal control rod to another lever with hose clamps and zip ties! It never really worked properly. I have removed all of that crap and returned it to normal, however since I put the new ones in, now I've noticed that the original control rod on the driver side is missing. This part appears to be discontinued everywhere I can find, but if anyone out there might know a place or website that doesn't come up with google searches for the part # it would be much appreciated! I plan to check local dealership parts departments and junk yards as well, but that doesn't seem likely to work out. I'm also considering having this fabricated if it comes to that, since I have the passenger side to work with.
I believe I'm looking for part # 15689040, which should be the rod connecting the actuator to the part above it. Thanks!
