Driver and passenger exterior door handles...loose.
Postby DaHonu [OP] » April 9th 2020, 12:27am
Both exterior handles will open the doors ('05 Astro LT AWD), but both are loose ie. the leading edges of both handles are angled toward the center of the van with "spring tension" in finger relief space on the doors where the handles sit...iow, the outside surface of the handles are not parallel with the door skin when at rest (make sense?). My question is...since I can open the doors in spite of their abnormal positions, does this mean that something slipped off inside? Or does it mean that something broke off inside and that I will need to replace it with new ones or good ones from the JY?
After reading the horror stories about replacing these handles, I'm very sure that I'm going to do the secondary access hole and save myself some grief and learning new swear words in tongue. Thanks for your help!
"Eddie would go..."
- Mark Foo (Surfer)
DaHonu
Topics: 9
Extra Info: LT AWD
  • '99 Safari "Quality" Door Handles?
    by FGravity » May 15th 2020, 6:28pm in Exterior
    August 5th 2020, 11:58pm
  • 1994 Safari Exterior Fuel Door
    by edwina » September 13th 2020, 5:04pm in Exterior
    September 14th 2020, 3:18am
    7
    44
    October 25th 2020, 6:03am
Re: Driver and passenger exterior door handles...loose.
Postby sixsixsixsix is online! » April 9th 2020, 1:11am
I just put a new handle on our driver's side and the new one 'slants in' also just like you say. Works fine, looks wonky.
Can not remember where it was from.
Well, after all... what would Banacek say ?... “Everything needs to change except the asshole culture and stupid way of life of the avg. antifa, BLM follower - slobs, cowards, killers w/o any thought that they, IN FACT, are now the Racists.”
Firing on 3 Cylinders (L5)
Topics: 37
Images: 1280
Postby Astrofarian » April 9th 2020, 4:04am
Yeah, my original 89 had a passenger front handle like that, the 92 "Hoopty" had both fronts like that and yada yada yada. Get some new handles ready and treat the ones on there with kid gloves. They all seem to let go sooner or later. Read up on changing the handles. You'll be doing one at least at some point.
I hope I'm wrong, but get your kit together in case I'm not.
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby DaHonu [OP] » April 9th 2020, 5:39am
I intend to get replacements regardless because experience indicates you all are right. I just wanted to know (without pulling off the panels and peeking with a scope in the meantime) if how it is sitting at rest was caused by something that slipped off or broke off the mechanism inside. I should get a Haynes or Chilton asap, huh?
"Eddie would go..."
- Mark Foo (Surfer)
DaHonu
Topics: 9
Extra Info: LT AWD
Postby augidog » April 9th 2020, 8:18am
Same problem here, and also steeling myself for the job.
Look behind your loose handle and you might be able to see a hinge tab has snapped off. Maybe we get the collapse when both tabs break? I think we can baby it along because of the spring return and the connection to the linkage, but clearly a final piece will inevitably snap and then we're climbing in through the side door.
reviews and opinions on the best replacement vary greatly, and I haven't yet made my choice.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby DaHonu [OP] » April 9th 2020, 3:03pm
Thanks for the pic, augidog, it helps me understand whats going on a bit. I'll be creating the secondary access holes in both doors soon for the inevitable...I checked with my trusty Magic 8 Ball...and got the bad news.
"Eddie would go..."
- Mark Foo (Surfer)
DaHonu
Topics: 9
Extra Info: LT AWD
Return to Exterior
It is currently October 25th 2020, 6:03am
Exterior Forum
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
AstroOafAdventurer
in Exterior
Comments: 0
Date: Oct 21 '20
Time: 8:16pm
Tanino
in Exterior
Date: Oct 18 '20
Time: 5:34pm
Olivier02
in Exterior
Date: Oct 11 '20
Time: 8:40pm
