Replacement Sliding/screen window
Postby Digidonny [OP] » April 20th 2020, 2:01am
Hey all ! I am wondering if anyone knows of a replacement window for the drivers side "popout existing window" My bunk is there and really need the air flow of a nice open window. Like an RV camper window. I have a 03 Astro Thanks!
Digidonny
Extra Info: Leather
Re: Replacement Sliding/screen window
Postby icebrrg3rd » April 20th 2020, 5:17am
Not sure there are any direct replacement for the stock window. Most conversion vans start with a cargo van and get a hole saw-zall'd into it (usually cutting supports). And those windows usually don't have the same compound curves as the stock windows. I'm also going to guess that even though it looks like it, the stock window isn't a perfect rectangle, where the aftermarket/RV/conversion van windows usually are. Probably only way to put an aftermarket window in is to find one bigger than the stock opening and start cutting.
My opinion is it's better to make a screen that you can attach with magnets over the opening of the stock pop-out window and put a vent fan in the roof, those seems to help with interior temp control fairly well.
-Andrew
91 Chevy Astro 5L 5-speed, Ford 9" 261k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 213k mi
10 Chrysler Town & Country 3.8L 180k mi
icebrrg3rd
Firing on 5 Cylinders (L3)
Years of Membership: icebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full yearsicebrrg3rd has been a member for 10 full years
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Postby Rod's Trucks » April 20th 2020, 6:04am
I took a couple of pieces of mosquito netting, and sewed several magnets into pockets around the hemmed edge.
I can prop the windows open, attach the magnetic screen on both side windows if desired.
Rod's Trucks
Topics: 19
Images: 44
Alias (AKA): Rod and/or WE7X
Postby Wiley » April 20th 2020, 4:13pm
Cutting a rooftop fan is probably easier. A tree fell on my van and broke some windows, so when replacing I had to cut out the old seal/glass on the back fixed window. While I am sure the harbor freight tool didn't help, it sucked cutting the old window out. Maybe a better tool makes it easier, but it was a lot of work. A lot of us have done the fans, though maybe you are trying to be more stealth.
A cheap easy fix, when I was traveling I used a bike cable lock and popped the hatch, the lock made sure it only opened a couple inches, allowing airflow at night.
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Postby sixsix » April 20th 2020, 5:03pm
Well, if you're talking about the pop-out windows, like in the doors - go to a JY - they are not avail OEM sale anymore.
If you are referring to aftermarket conversion-type windows, sliders, etc, go to an RV or outdoor automotive shop.
Well, after all... what would Banacek say ?... “It is only a matter of time before armed citizens, waiting or not for the police, take things into their own hands, fire on the rioters for personal and property prot. & end up hunted like dogs.”
Firing on 2 Cylinders (L5)
Topics: 37
Images: 1254
Postby AstroWill » April 23rd 2020, 7:46am
Digidonny wrote:Hey all ! I am wondering if anyone knows of a replacement window for the drivers side "popout existing window" My bunk is there and really need the air flow of a nice open window. Like an RV camper window. I have a 03 Astro Thanks!
I have never seen one to fit inside the stock window opening. But you could get a filler panel from the JY, maybe even one that already has and RV style window in it. Weld that into place and be good to go. I have made screens to go in mine, but a fully opening window would flow a lot more air than the tilt out style esp if you aren't using a fan of some sort.
Topics: 106
Images: 437
Postby Digidonny [OP] » May 5th 2020, 4:24am
Thanks everyone... the roof vent seems like a good idea. I am surprised with the popularity of these vans an RV company does not make an exact replacement slider. Cheers !
Digidonny
Extra Info: Leather
Postby icebrrg3rd » May 6th 2020, 4:22am
You have to remember, when the conversion van was popular, the companies would get cargo vans and cut up the sheet metal and toss in a window that would work on a Chevy, Ford, Dodge, etc. What would be the benefit for making a specific window to replace a stock window for a certain make & model of van. Kind of limiting.
Now that the youngest Astro is at least 15 years old, and vans are a very niche segment already, let along the ones being modded into RVs, there is even less economic benefit to making a specialty window. Just try and find any aftermarket product for the Astro nowadays, back in the 90's magazines had plenty of ads for stuff to customize your van. Ah, if only I had stockpiled that stuff...
-Andrew
icebrrg3rd
Topics: 49
Alias (AKA): Andrew
Return to Exterior
It is currently September 21st 2020, 2:35pm
Exterior Forum
SoccerMom4x4
in Exterior
Date: Today
Time: 3:15am
Tanino
in Exterior
Time: 11:44am
SoccerMom4x4
in Exterior
Date: Sep 17 '20
Time: 3:25am
Sailing_Faith
in Exterior
Comments: 20
Date: Sep 11 '20
Time: 6:13am
hippovan
in Exterior
Comments: 0
Date: Sep 10 '20
Time: 11:26pm
Users browsing this forum: kjckjc is online! and 14 guests
