Remove gasket material and adhesive from rear doors
Postby Road Captain [OP] » May 2nd 2020, 3:04pm
I purchased the replacement gaskets, rubber adhesive and adhesive remover from SRP and they look like a nice replace. I read the instructions on the Adhesive Remover spray can and it say's to be used for removing adhesive prior to curing. Well, it's safe to assume the black adhesive on my doors is beyond curing.
What is the best way to get the old black adhesive off the doors? Is it the Adhesive Remove I ordered?
Dan
Road Captain
Extra Info: LT 4.3L V6 RWD
  • Remove License Plate / Rear Door Handle
    by Ladytron » July 10th 2020, 4:11pm in Exterior
    July 10th 2020, 10:32pm
  • Question about Rear hatch lift sensors
    by BigLoudJoe » July 24th 2020, 5:34pm in Exterior
    July 26th 2020, 2:09pm
    7
    82
    December 3rd 2020, 9:33pm
Re: Remove gasket material and adhesive from rear doors
Postby augidog » May 2nd 2020, 5:00pm
Yes...the 3M remover worked great. My fingers/knuckles/wrists still ache from when I did mine, but after a lot of rubbing i finally saw clean paint. Use sparingly, a small area at a time, because any runoff is only a waste. Messy job, but I was lucky having a ton of old socks to work with.
What parts are you working with? I recently replaced the entire Dutch Door set. You may find helpful info & pics here: https://www.astrosafari.com/viewtopic.php?f=11&t=141714
Here's your welcome wagon gift, original "Product Information Guide" for your van: https://www.gmheritagecenter.com/docs/g ... ro-Van.pdf
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby Road Captain [OP] » May 3rd 2020, 11:37am
I found the 3M Remover worked good at removing pieces of the old gasket that remained on the door after the old gasket was removed. So it does help with cleaning of the door but it was a lot of hard work removing the old black adhesive but I'm happy with the results.
I installed the SRP read door gasket kit for the 2005 Astro, because my drip pan gasket was in very good condition I did not install the drip pan gasket that goes across the top of both doors.
The gasket on the left door came out good and closes nice and after I installed the right door gasket I found the right door will latch but is not flush with the left door, it's off by an each 1" or so. I have an e-mail in to SRP asking what can be done.
Road Captain
Postby albrow100 » May 4th 2020, 2:27am
I used one of these when I took my seals off it burns off the residue easily!
https://www.amazon.com/3M-03612-Adhesiv ... B005RNGN8I
if you press too hard it will take the paint off though
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby rstro » June 4th 2020, 11:51pm
Road Captain wrote:I purchased the replacement gaskets, rubber adhesive and adhesive remover from SRP and they look like a nice replace. I read the instructions on the Adhesive Remover spray can and it say's to be used for removing adhesive prior to curing. Well, it's safe to assume the black adhesive on my doors is beyond curing.
Dan
I’m in the same boat. The passenger side, rear barn door shuts pretty close when I slam it. But there is a touch room left over, and there’s a leak in it that is driving me bonkers. I’m not thinking of the latch or striker bar to try and draw this door in more.
Did you find a solution?
rstro
Van Model Year: 2001
Extra Info: Cargo
Return to Exterior
It is currently December 3rd 2020, 9:33pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
